First post, by haradan
Hi. I have a problem I don't understand. I was using DOSBox 0.72 for Mac on my MacBook Pro CoreDuo (OSX 10.5) without a glitch. Then, my Mac had an accident last month and I had to change the hard disk and some memory.
Now, I was re-installing all my old programs and for some reason, I can not make DOSBox find the configuration file. It always starts in its default mode. I need it to read the config file since I'm using MIDI and I don't know of a way of telling DOSBox how to look for midi devices once you are inside the program.
The program actually works fine if I just try to run a game, but I don't know why it doesn't find or read the configuration file. The file is named "DOSBox Preferences" without an extension, and I placed it in the /Library/Preferences folder and in the Applications folder as well, but DOSBox doesn't seem to find or obey it.
I also tried using the config -writeconf command. It did write a file, but it doesn't obey it as well. Please, I need some advice on this one, I have no clue about what happened!
Thanks in advance.
