First post, by fbustama
I need to run an 8 bit app in DOS in my MAC. i've foun DOsBox but i can't configure how to increase the 640 KB base memory... does enyone know how to
thanx
Reply 1 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
that is impossible. (in any dos btw)
Water flows down the stream
Reply 2 of 6, by MiniMax
Rank Moderator
Moderator
8 bit app?
_________________
Reply 3 of 6, by fbustama
Sorry ....16 bit
Reply 4 of 6, by wd
Rank DOSBox Author
DOSBox Author
640k is the limit for base mem
Reply 5 of 6, by ih8registrations
Unless you're using qemm. I haven't tried qemm in DOSBox but should work in virtualbox or qemu, which there's mac versions for of course. Qemm had an option to up conventional memory to 736k or so, reclaiming various video bios areas. That means you can't use certain video modes, but if your program didn't use them and needed the memory, this option is for you.
Reply 6 of 6, by wd
Rank DOSBox Author
DOSBox Author
Continuous basemem is 640k (639+x usually for special bios stuff)
and even if the bios stuff is not there/moved you can only use 0xa000
when not in graphics mode,
Besides that dosbox has 128k of umb mem (ems=false) attributing for
the non-continuous additional memory.
