First post, by ih8registrations
Rather than rewriting a ram drive, use one of the ones already available.
http://www.ibiblio.org/pub/micro/pc-stuff/fre … es/dos/ramdisk/
srdsk209c.zip
http://www.mdgx.com/dos.htm
They need to be loaded as a device from the config.sys, but that's where this post comes in. There is a dos utility that lets you load devices from the command line, anyone know it? I forget what it's called and SNR is high searching with generalized keywords. Anyway, there's the possible solution for using a ramdrive in dosbox.
