First post, by DaveDoesIT
Hi all,
I am using XP and DosBox to run win3.1.
Using win3.1 explorer I can see the files in my DosBox-mounted drive as expected but if I Alt-Tab back to XP and copy a file from a networked PC into the mounted drive, then Alt-Tab back to win3.1 I cannot see the new file.
I tried closing win3.1 and restarting but the file is still not visible.
Not only do I have to close win3.1 but I also have to close DosBox and start it all up again so the new file is included. It seems as though DosBox takes a snapshot of the files when mounting the drive at start up.
So here's the queston: Is there anyway to refresh DosBox after I have used XP and the network to add a new file to the DosBox-mounted drive?
I hope you can follow that.
Thanks.
Dave
