First post, by wardrich
I couldn't really summarize this problem in the title... but here's what's up. I'm using Ubuntu 8.04 (Hardy) and I installed dosbox from the repo. Everything is fine, but I find that the dosbox.conf file has to be in the pwd when I launch dosbox or it won't load.
Example:
dosbox.conf is saved in ~/
pwd is ~/games
Starting dosbox will cause dosbox to run as if there is no dosbox.conf.
I've even tried moving the .conf file into /usr/bin
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
that is correct
if you want an always load it configfile: ~/.dosboxrc
Water flows down the stream
Reply 2 of 2, by wardrich
Ohh, I saw that in the readme, something about dosboxrc, but I didn't get entirely what it meant. Thanks 😀
