First post, by spudgunman
I made this because I didnt see that dosbox actually will mount a zip file, So I went to the work to make something that worked with my front end.
wanted to post it up if it helps anyone....
http://www.kellykeeton.com/blog/2008/10/18/lo … IntoDosbox.aspx
edit: updated and fixed the issue with OP
Reply 1 of 3, by MiniMax
Rank Moderator
Moderator
Interesting post. So full of thought provoking ideas.
_________________
Reply 2 of 3, by spudgunman
is there a restriction on my post some how I cant see anything but I can quote and reply?
Reply 3 of 3, by MiniMax
Rank Moderator
Moderator
No restriction, but the forum software seems to error out if you put the [ / url ] on a separate line. I fixed your post.
_________________
