disable alt + tab
First post, by nicaso
hello
is it posible to disable the alt+tab function from ms windows while playing a game in dosbox.
for example in extreme assault i often use the alt-key and sometimes the tab-key. and when i use them together for doing 2 actions in the same time i left the game into windows. maybe there is a simple solution, that i have not found yet.
thank you everybody for help.
Reply 1 of 1, by wd
Rank DOSBox Author
DOSBox Author
Nope isn't possible (applications can't intercept it afaik, only system apps),
but you can remap the tab key if you wish.
