First post, by lnlver
Is it possible to 'mount' more than one directory when using DOSBOX?
For example, can I mount both of my E:\DATA and D:\WOLF3D directories and access the files in each in a single application of DOSBOX?
I developed some software which works across different drives and directories. I would like to know if DOSBOX can work in this environment.
