vdmsound not work
First post, by alphacentauris
I have replace my motherboard MSI-KT4 and my cpu XP1800+ by gygabyte 7VAXP-A ultra with XP2800+... After full reinstall including vdmsound 2.0.4, no sound in emulation, and creative diagnose report sb card not found. WIth kt4 and xp1800+ no problems.
Reply 1 of 26, by Snover
If the Windows Creative Diagnostic utility is reporting no sound card found it isn't VDMSound. I don't think the old DOS Creative utility would find VDMSound anyway, but just in case, what files do you have with the string "Ke386" in them?
Yes, it’s my fault.
Reply 2 of 26, by Nicht Sehr Gut
Originally posted by Snover I don't think the old DOS Creative utility would find VDMSound anyway, ...
It doesn't. Confirmed that on mine. I think Creative's tool is doing something nasty at a low-level.
Reply 3 of 26, by alphacentauris
With my previous computer, diagnose work perfectly (and dos game DUNE2, EOB, DUNGEON MASTER also).
With current harware/software configuration, is now not possible for emulation to work...
Reply 4 of 26, by alphacentauris
Emulation of midi not work too
May be my computer is too fast ?
Reply 5 of 26, by Nicht Sehr Gut
Originally posted by alphacentauris With my previous computer, diagnose work perfectly (and dos game DUNE2, EOB, DUNGEON MASTER also).
Was your previous system using Windows 95/98/98SE/ME? If so, that's not relevant. XP has no DOS whereas Windows 95/98/98SE/ME did.
My not being able to run DIAGNOSE in XP is irrelevant, as it serves no purpose in XP. I still run DOS programs with VDMSound just fine on a daily basis.
What we need to find out is why your audio isn't working.
Like Snover has suggested, I suspect that something accessing your hardware directly, a no-no for XP.
Suggest that you try this:
Download Ms. Pac-Em from this thread:
showthr...p?threadid=1542
Use either installer and run MSPACEM.EXE with and without VDMSound. Without should give you poor audio and (probably) no music when starting the game. With VDMSound, should give you good quality sound effects and music.
Does it work properly?
Reply 6 of 26, by Unregistered
My previous harware using Windows XP-SP1 may be with first edition of directX 9...
your link has gone (404)...
now i try your suggestion...
Reply 7 of 26, by Unregistered
Your link:
showthread.php?threadid=1542
I try to ms pac man, but black screen only after logo... only when using emulation mode.
This situation does not exist with my previous harware configuration.
For the peace of my mind, i retry the test in my work computer, a XP PRO FR SP1 and old dfi AK74-SU with amd 900...
The only thing have changed has upgrade to directX9.0b... i have a sound with dune2, but there are delayed for digitalized sound, and dune finish to crash after more sound are not played...
may be this problem does dot occurs if using directX 8.1, but it is necessary to reinstall windows XP on another disk or partition pour check if the case occur by any new microsofs fixes or directX 9, specially in version 9.0b after microsoft fixe this version for security reason....
Reply 8 of 26, by Snover
Could you please find someone that can speak English better to write your posts for you? I cannot understand a word of what you're saying.
Yes, it’s my fault.
Reply 9 of 26, by alphacentauris
I'am sorry for my poor english (if you may read french ?). I have printed all of this post for my brother helping me (later) for more comprehensive words...
I am just finished testing full install on a MSI KT3 + athlon 2000+ sblive 5.1 + and all laster drivers and fixes from nvidia, via, microsoft (including directing directx 9.0b)... and it's working fine...
May be vdm sound don't like my audigy 1 and 2 ???
to be see later...
Reply 10 of 26, by alphacentauris
I have activated on my motherboard gygabyte my audio soundship realtek and i tried to use it with vdm sound : no success.
Have you a motherboard with a amd barton XP2500+/2800+ min. , Windows XP SP1, directx 9? is vdmsound working fine in this case ?😕
Reply 11 of 26, by Nicht Sehr Gut
Originally posted by Unregistered I try to ms pac man, but black screen only after logo... only when using emulation mode.
Then you have problems well beyond running VDMSound. Even if the game could not use VDMSound's audio emulation or XP's built-in audio emulation, the game should still run with PC-speaker audio.
Since it did not, that tells me you have other problems. Open a command prompt and type EDIT. If it doesn't start in full-screen mode, press ALT+ENTER to make it full-screen mode.
Tyr using your mouse with it to open a TXT file. Does it work?
Originally posted by alphacentauris I'am sorry for my poor english (if you may read french ?).
You might try contacting Zorbid or one of the other board members that can speak French.
Reply 12 of 26, by alphacentauris
Hello, i have a good (?) new for my problems.
I have removed mcafee viruscan 7.0 on my system (bdr+disks included), and now the emulator is working...
After reinstalling 7.02, a have a partial emulation (no midi emulation is currenly working)...
Regards
Reply 13 of 26, by Snover
Oh lovely, McAfee. I knew their shit was bad, I just didn't realise it was that bad, my god. Thanks for the info.
Yes, it’s my fault.
Reply 14 of 26, by Nicht Sehr Gut
Originally posted by Snover Oh lovely, McAfee.
Hold on. How can that be it? About the only way I can see it interfering is if "Auto-Protection" was left on during the install of VDMSound.
Even then, why would he still not have MIDI emulation if McAfee was the culprit? Besides, I've run VDMSound on a machine with McAfee AntiVirus Pro 7 and VDMSound seemed fine.
I suspect that this is yet another case of "mystery program that allows direct hardware access".
alphacentauris, do you have a "motherboard monitor" program or some similar program on your PC?
Reply 15 of 26, by alphacentauris
No, because i have no monitors programs for my gygabyte...
In this computer, i have only for system :
- OS Windows XP SP1 + all fixes (patches) from microsoft
- Audigy 1 laster driver (2003)
- laster via4in1 (47)
- detonator 45.23 driver for my geforce4200
- divx 5.03
- mp3 cyberlink power pack XP
- sygate personal firewall 5.1
- mcafee viruscan home edition 7.02
When mcafee exist on system, i have not only emulation problems but vdmsound crashed when i have more 2 files exported, by example the log+export sb wave+adlib wav...
An exception occured in thread 0 ((null))
Erreur 0xc0000005 - l'instruction ß "0x
fault location :0x21503ff
parameter:0x0000000000 0x21503ff
When if have captured only the Sb wav, the content of data for this file is 0 (header are good).
And after removing (NOT only disactivated), i have not crash, i have the sound, and captured data containt valid sound...
I don't know why this problems occurs with viruscan (i have very surprised) but i have investigating...
I have contacted vlad for this problem (in french).
I have download the source for studies this problem too, but my visual c++ does not recognise properly the projet / workspace files...
If you have any ideas...
Thank
Reply 16 of 26, by Snover
hah, look at that! The thread 0 ((null)) diskwriter.dll problem did not start as of 2.1! I KNEW IT! VLAD! BAD BOY, WRITING FAULTY SOFTWARE!
Yes, it’s my fault.
Reply 17 of 26, by Nicht Sehr Gut
Originally posted by alphacentauris No, because i have no monitors programs for my gygabyte...
There is always the possibility that you have a program allowing direct hardware access an you may not know it (this has happened to several other people).
Check your system to make sure it's clear of GIVEIO.SYS files and files that contain the word "Ke386". If you use Window's "search" tool, you need to make sure that it searches for hidden and system files and directories.
alphacentauris, when you are walking on eggs...don't hop.
In other words, when you are try to get basic sound working in your games don't be turning on the tools to dump WAV samples for soundblaster and adlib. Only turn on those on when you actually need them, and even then, I would not turn on more than one at a time.
Quite possibly, McAfee was try to scan the sound files that VDMSound created as they were being created. I can see that causing a crash.
He's gone for a while. It may be some time before he sees the email...
Reply 18 of 26, by Nicht Sehr Gut
Originally posted by Snover hah, look at that! The thread 0 ((null)) diskwriter.dll problem did not start as of 2.1! I KNEW IT! VLAD! BAD BOY, WRITING FAULTY SOFTWARE!
Yeah, but why does it only show up under certain circumstances? Remember my comment about XP-Pro vs XP-Home?
Reply 19 of 26, by alphacentauris
Hello,
After many test, i have discoved that when before using wdmsound, if i open the control panel->multimedia options (sound card), after, vdmsound work !
With this clue, i have beginning to suspect device selection into vdm lauchpad.
When starting a session, if i am leaving all devices, that may be work.
If i am selected explicit device, ie audigy wave port, the crash occurs. I have reproduce this case in another computer without viruscan (with trend client).
If i am selected direct sound devise, i have not crashed vdmsound.
now, if am retry with selecting my device "audigy wave port" in sb parameters, i crash. OK.
Now, if i have loaded before my control panel, the crash does not occur after, when i attempt to restart dune2.
it's not curious ?
I am not found the file giveio.sys in my system.
I am not found "ke386" string in all of my files.
Thank
