First post, by ppravier
I've got Day of the Tentacle to run wonderfully with VDMSound.
However, the mouse doesn't work in the game.
What should I do ?
Reply 1 of 4, by Snover
POSTING GUIDELINES!
Specifically, what are your specs, and what have you tried to resolve the problem?
Yes, it’s my fault.
Reply 2 of 4, by ppravier
Sorry for that.
My specs :
Windows XP Pro
Athlon 1330
Souris PS/2 Microsoft Explorer optical
Geforce 3
Soundblaster Live
I have tried to load a mouse.com driver in the autoexec.nt used by VDM sound. In the dos window, mouse.com says that it has activated the existing mouse driver.
Unfortunately, it doesn't change the problem.
In the game, I have selected the mouse support, without success.
In other DOD program such as Edit, the mouse works.
Reply 3 of 4, by Snover
You shouldn't need to use mouse.com to get your mouse working in DOS. All games I've played have run fine with mouse support without any intervention on my part, so I'm not sure what's going on. If your mouse is stuck in the upper-left corner, use SETMOUSE and see if that doesn't fix the problem. If not, I mean, I haven't heard about this problem from anyone else, and believe me, scores of people play/have played DoTT here. 😀
Yes, it’s my fault.
Reply 4 of 4, by bgbennyboy
Use the 'm' parameter when you run DOTT
eg tentacle.exe m
