First post, by POLE
POLE
Offline
Hello. I know I bothered you a lot with my recording problems, but I stumbled on yet another problem.
I tried to record Bioforge (such a great game) after recording the Alone in the Dark series. The video was unsynched (as usual), but when I used the option to "Process every 2 frames", the video remained unsynch.
I tried everything I could, but nothing worked. I even tried changing codecs.
I have my suspicions that it's because Bioforge setting the CPU cycles to max (while I had to manually set them with Alone in the Dark), but I couls be wrong.
Is there any workaround for my problem?
Thanks in advance.
