First post, by Leolo
Hi people,
I'm desperately looking for a program exactly like this one:
http://www.parhelia-tools.com/products/pathsc … athScanner.aspx
but I want one that can run under WinPE/BartPE. The above mentioned program doesn't work because it needs the damn .NET framework 🙁
Do you know if such a program exists? Where could I find it?
PS: I swear I've tried very hard googling for it but couldn't find anything!
Kind regards.
Reply 1 of 3, by Jorpho
If you're really that desperate, it seems like the sort of thing that would be trivial to do with a few lines of Python.
Reply 2 of 3, by Leolo
Hey, thanks for your reply!
Does a Python script need some kind of "engine" to run? Or can it be self contained inside an executable?
My main problem is that I need the tool to run under WinPE, which is a castrated version of Windows containing only the bare minimum components.
I've found also this program:
http://www.theutilityfactory.com/summaries/fi … g-filenames.htm
It can be "coerced" to run under WinPE by copying some missing DLLs that it needs, but it's shareware and I can't justify buying a complex product when I'm going to use just one feature.
So, I guess I'll keep searching, I'm sure there must be a tool somewhere that does what I need!
Regards.
Reply 3 of 3, by Jorpho
Not sure about compilation, but you can certainly run a Python script in any Python interpreter. I think the standard Windows interpreter does not require any fancy libraries in order to run.
