keystroke problem
First post, by downinahole193
hi. um, i used to use dosbox ALL the time. i just got a new computer which has windows vista 64bit. it will run dosbox, but when i try to type c:\ i get c;] which makes no sense to me. my keyboard works fine, it's just like dosbox isn't registering the right keystrokes.
does/has anyone else had this problem? if so, help! thanks.
Reply 1 of 1, by downinahole193
i also can't make a ~
... i read through the readme and it says to make the keyboard layout US. fine. and i can also use a foreslash unstead of a backslash. but i need the ~ and it's not happening... this is lame.
