First post, by Silent Loon
- Member
I just bought an old Soyo SY-4SA2 with a 486dx2-66. Nice board as it has ISA, one VLB and PCI slots. Nevertheless it stops booting while attempting to acess the hd ("harddisk(s) fail 80). Also it doesn't recognize the floppy disk at all (no characteristic noise when you turn on, no error message). I can access the bios, and enter the parameters needed, but that doesn't help. I also tried to boot with an isa ide controller, same results.
I know that most likely the board is defective, but perhaps I've overseen something. The battery was low and at the end of its life, so I builed in a new one, hoping that the error will disappear - without effort.
My last idea was that because of the rotten battery the bios itself could be somehow corrupted - is this possible or just wishful thinking?
Also on the soyo site it is said that this board (or at least the 4sa?) came with an eeprom bios and that I should use an eeprom writer (which I don't have). But jumpers on the board let you choose between eeprom/flash and flash only bios. It has an Award Modular Bios (4.50G).
Any suggestions?
