First post, by bestemor
- Oldbie
- I have made a copy(image) of an older HDD with a working version of DOS622 and Win311 on it. Transferred to another small HDD, fat16 and everything. All software settings remained unchanged of course.
Been testing a bit on an Abit BH6 motherboard(was testing the board itself actually, and decided to let the HDD join in), with no soundcard, no floppy or CD attached - just the barenaked MB + a random 1997 PCI VGA card.
I get DOS running, no problem, even played a bit of the games on the disk.
But then tried starting Win311...
- I only get to see the logo screen(not even to the 'desktop'), and then it's total freeze 😮
BUT, when I put in the old VGA card from the original machine, it boots just fine, only various complaining about the missing Soundblaster...
What gives ?
Maaybe, if I was able to get a slightly more modern VGA driver for win311, it might help for any newer PCI cards?, but then again maybe not... ?
- ok, sorry for the rambling, but have no experience with Win311 misbehaviour - the parent machine worked just fine for 12+ years, and same for the Win311 installation.
And, I admit it MAY have something to do with the totally unprepared soul transplant(HDD contents moved), but as DOS works so well with no files or settings changed, I expected to get Win311 to at least boot, if nothing else...
PS:
oh, and I also remember recently getting an original 2MB Vram memory module for the older VGA card - making a total of 4MB, but when plugged in, Win311 started to show a fuzzy double/split screen or similar nonsense, so I just took it out again.
Very touchy OS that is... sigh 😵
