First post, by dochawk
I'm running FreeBSD 7-stable on a Compaq Presario F767NR.
I compiled dosbox .72 from the ports, and it just works; I can launch straight into Master of Orion, and even get sound effects (I don't know about the music; I didn't run it that long).
When I shift to full screen mode though, and also if I start in it, the screen doesn't start for 100 lines or so, leaving the bottom eighth or so of the dos screen below my physical screen.
googling and wikiing hasn't been much help, and I don't see any parameters to set for this.
Thanks
hawk
