First post, by diablo75
I am currently using Windows XP with the most recent version of DosBox I just downloaded today. I am trying to play Descent/Descent 2, and the setup program (for setting the sound card settings) says it can't autodetect the audio card. The card that appears to be emulated is a Sound Blaster 16 with the default DosBox IRQ/DMA address assignments (IRQ 7, DMA 1). If I try to set the settings up manually and do an audio test it either fails (no sound) or at best, I get extremely choppy, unintelligible sound.
The sound card that is actually in the computer is some kind of on-board SoundMAX chipset. Windows itself plays sound just fine. But DosBox doesn't seem to work.
Reply 1 of 1, by MiniMax
Rank Moderator
Moderator
My config:
# Title:        Descent 1.4a
# Developer: Parallax Software
# Publisher: Interplay Productions Limited
# Year: 1995
# Genre: 3D first-person shooter
# Status: Commercial license
# Link: http://www.descent3.com/
# Link: http://www.planetdescent.com/
# MD5-sum: a6f2203ccf08bef25c003fa0609f6165 *DESCENTR.EXE
# Archives:
# Run:
# Setup:
# Save-games:
# Game-configs:
# DOSBox: 0.72
# By MiniMax
[sdl]
# Descent can be run using different resolutions. From the README-file:
# -320x100 Uses a low-res graphics mode good for full screen playing
# on slower computers. A bit blocky, though.
# -320x240 Uses a little better resolution than normal for a crisper
# image. Uses ModeX page flipping to reduce "shearing."
# -320x400 Same as above, but much more resolution at the expense of
# speed. Only recommended for P-90's and above!!
# -640x400 Killer high res. Requires a VESA driver.
# -640x480 Super-killer high res. Requires a VESA driver.
# DOSBox is capable of running Descent in the 640x480 resolution mode.
# Using an output method like 'overlay' that supports hardware scaling to
# a window twice the resolution (1280x960) works nicely for me.
output=overlay
windowresolution=1280x960
[render]
# The scaler does not affect the main game graphics, only the lower
# resolution graphics used in the game menus and mission briefings.
# I like the hq3x scaler.
scaler=hq3x
[gus]
# The auto-detection in the Setup program defaults to the Gravis
# Ultrasound device if present, but complains about a driver not
# being loaded when testing music. Wiser men than me says it is
# because I need to load some MIDI-patches into the GUS first.
# Anyway, disabling it here avoids the whole mess. Feel free to
# enable it if you want to experiment with it.
Show last 105 lines
gus=false
[ipx]
# Descant can do multi-player!
ipx=true
[autoexec]
@ echo off
rem +---------------------------------------------------------------
rem ! Mount the CD-drive and virtual harddisk.
mount C "C-drive"
imgmount D "G:\Spool\ISOs\DESCENT.iso" -t iso
echo.
rem ! Are we ready to run the software, or do we need to install it
rem ! first?
if exist C:\Games\Descent\DescentR.Exe goto Ready
:Install
rem ! Install the software from the CD-drive using the supplied
rem ! installer. The installer will also invoke the setup utility.
rem !
rem ! OBS: After installing you are forced to watch through a little
rem ! trailer for Star Trek: Starfleet Academy.
D:
cd \
echo Installing Descent.
Install
if not exist C:\Games\Descent\DescentR.Exe goto Done
:Levels
rem ! Install the Levels of the Worlds expansion packet (if
rem ! available).
if not exist D:\Levels goto PostInst
copy D:\Levels\*.* C:\Games\Descent
:PostInst
rem ! Additional post-install actions.
rem ! Create a fake electronic registration card file indicating
rem ! we do not want to register Descent by sending registration
rem ! information by modem or by printing out and mailing the
rem ! card.
C:
cd \Games\Descent
echo [STAMP] > eRegCard.Ini
echo product=DESCENT >> eRegCard.Ini
echo counts=0 1 0 >> eRegCard.Ini
rem ! Create D1VGA.BAT, a batch file to launch Descent with full VGA
rem ! resolution (640x480).
echo @rem Remove any leftover swap files. > D1VGA.Bat
echo @if exist *.Swp delete *.Swp >> D1VGA.Bat
echo @DescentR.Exe -640x480 %%1 %%2 %%3 %%4 %%5 %%6 %%7 %%8 >> D1VGA.Bat
echo Done!
echo.
:Ready
rem ! Switch to the harddisk, and inform the user about which
rem ! command to use for running the software.
C:
cd \Games\Descent
echo Type DESCENT to start the game.
echo Type D1VGA to start the game in hi-res VGA mode (640x480).
echo Type DESCENT -help to show additional options.
echo Type SETUP to reconfigure sound and VR devices.
goto Done
:Done
echo.
_________________
