First post, by Luzie
Hi,
I looked around here, but I can´t find a solution for my problem:
How can I pass Commandline-Parameters to a Batchfile i start with [autoexec] in the dosbox.conf ?
E.g. I have in the dosbox-conf Autoxec-Section:
DIR %1PAUSEEXIT
Then, when I start DosBox.exe via the command-line:
DosBox.exe c:\*.*
I don´t get an "DIR C:\*.*" as I need.
Is there a way to pass anything from commandline of DosBox.EXE to
a Batchfile I start within the DOSBox-Autoexec-Section ?
Regards,
Luzie
