First post, by BachManiac
Hi!
I want to make all my old Dosgames easily working on Windows.
Therefore I take a copy of Dosbox for each game and only by starting dosbox the game starts too, programmed in the autoexec.
so I don't have to give any command in the dosbox-command to start the game.
so for example, look at this screenshot:
The Game folder includes Dosbox-portable and the game itself. When I start Dosbox portable the game startes automatically and when I exit the game, Dosbox closes automatically.
This all is no problem but now here is my question.
as you see I use Dosbox portable because I can copy this folder easily to another PC.
But one problem prevents me from being 100% portable.
in autostart I must mount the game folder but there I must call the full path.
is there a "systemfolder"-variable available so I can use instead of:
mount c: d:\Games\Death_Rally\DRally
a command like this:
mount c: $dosboxfolder$\DRally
is this possible?
like in Windows: Windows have some "system-variables" like $systemroot$ for example.
please help!
tanks!
Reply 1 of 2, by DosFreak
If you execute the DOSBox executable in the specific game folder then you can just do:
"mount c .\"
It's possible that DBGL can be used on a USB drive. I believe relative path support was added sometime ago. I've never tried DBGL on a USB drive tho. It definetly would be better to use than having a ton of DOSBox executables and config files laying around.
Make your games work offline
Reply 2 of 2, by BachManiac
thanks!
mount c: .\ didn't work but
mount c: . workes!
thank you! 😉
