First post, by BasketCase
- Newbie
In a Linux system with more than one sound card is it possible to have DOSBox run on the second card? This could be done through alsa (hw1,0) or oss (/dev/dsp1).
try some SDL variable.
Water flows down the stream
I did some quick reading and I found some SDL variables that look right. I tried setting:
SDL_AUDIODRIVER=alsa AUDIODEV=hw:1,0
and
SDL_AUDIODRIVER=dsp AUDIODEV=/dev/dsp1
but neither worked.
However both settings prevented sound output completely and if I spelled out dsp1 or hw:0,0 DOSBox worked as normal so I think this is the right track.
oh geez,
I should have checked my logs. My syslogd was eating 80% of my CPU logging repeated kernel bug messages:
BUG: stream = 0, pos = 0xfffffffa, buffer size = 0x400, period size = 0x200BUG? (cpcm->pcm_channel)Pid: 27935, comm: dosbox Not tainted 2.6.26-gentoo-r4 #1[<fa8fb774>] snd_cs46xx_playback_direct_pointer+0x44/0x50 [snd_cs46xx][<c0416457>] snd_pcm_update_hw_ptr+0x37/0x200[<c011e870>] __dequeue_entity+0x50/0xc0[<c0416d1f>] snd_pcm_lib_write1+0x21f/0x2c0[<c011fdc9>] hrtick_set+0x69/0x140[<c04b289e>] schedule+0x24e/0x730[<c02c86d4>] rb_insert_color+0x64/0xb0[<c0416f2b>] snd_pcm_lib_write+0x6b/0x100[<c0417f90>] snd_pcm_lib_write_transfer+0x0/0xd0[<c04153a5>] snd_pcm_playback_ioctl1+0xf5/0x400[<c013a320>] lock_hrtimer_base+0x20/0x50[<c013a3dc>] hrtimer_try_to_cancel+0x3c/0x80[<c0415773>] snd_pcm_playback_ioctl+0x43/0x50[<c0415730>] snd_pcm_playback_ioctl+0x0/0x50[<c017aa6b>] vfs_ioctl+0x2b/0x90[<c017ab2c>] do_vfs_ioctl+0x5c/0x290[<c017ad9d>] sys_ioctl+0x3d/0x70[<c0102f6d>] sysenter_past_esp+0x6a/0x91
well I see no dosbox there actually.
DOSBox uses SDL to play the audio. All interfaces dosbox has to your soundcard (aside from midi) go through SDL.
