First post, by dstar
I'm seeing something odd, and haven't been able to find a solution. Just to make it clear, this is _not_ the problem with arrow keys not working, or if it is the same problem, usescancodes doesn't change anything.
My alt keys aren't working when I run Master of Orion under dosbox. Left alt does nothing, and right alt appears to be mimicking the enter key, afaict. Fiddling around in the keymapper doesn't seem to help. By default, it binds "key 307" and "key 308" to mod_2 in mapper.txt.
Any suggestions?
