First post, by retro games 100
I just wondered if there were any advantages in picking a specific DOS version for running DOS games. Is Windows 9x's 'DOS 7' the best for DOS games, or are there any speed or other advantages in selecting DOS 5 or 6?
Reply 1 of 14, by tikbalang
my pick is DOS 7.xx from win95c and later. it has advantages with regards to fat32 filesystem and memory management. fat32 give you drive partitions greater than 2gb. the himem.sys that come with these later dos supports XMS v3.x specs, meaning it can use more than 64mb ram. i don't see any speed advantages though.
ESS PCI DOS Drivers
_________________
Reply 2 of 14, by Malik
My favourite is DOS 6.22. DOS 5 was good enough for memory managent to load it high, but 6.22 is like, more refined a bit.
I stay away form anything higher than 6.22 though, for compatibility sake. Soundblaster's AWE32 dos install program can't run under Dos 7, if I'm not mistaken. And I also avoid it (Dos 7+) to prevent unexplained crashes and other weird problems while playing a dos game.
Reply 3 of 14, by retro games 100
Interesting. DOS 7 + DOS games = unstable?
Win 9x DOS does give you lots of extra goodies. Perhaps the odd crash, it's worth the extra aggravation?! 🤣
Reply 4 of 14, by Amigaz
Using IBM DOS 7 here aka PC-DOS 2000
Much more memory efficient than MS-DOS 6.x
Reply 5 of 14, by wd
Rank DOSBox Author
DOSBox Author
+1 for msdos 6.22 for the coolness factor.
Usually you can get a nice combo by dualbooting msdos622 and some win9x.
Reply 6 of 14, by gerwin
I have never really needed to revert back to Dos 6.22 since version 7.xx came preinstalled with windows in 1995.
Indeed the creative driver-installer refused to run in 7.10. But that check seems to only be there to make things unnecessarily difficult, as the drivers run fine, and the installers runs fine too when fooled with 'setver'.
Reply 7 of 14, by valnar
DOS 6.22 for me. Most compatible, period.
Reply 8 of 14, by swaaye
I've found DOS 7.x to be more than adequate for me. The convenience of FAT32 support is a really big plus. I imagine there are lots of old old games that don't like it tho.
My fav thing about DOS 6 is the thorough help system it has. I used to just sit around and read through that back in the day.
Reply 9 of 14, by retro games 100
Makes good reading today! 😉
Reply 10 of 14, by keropi
ofcourse, that is the right choise for a DOS only machine!!!! 😁
on my K6II and p200mmx I have installed win98SE and made it boot to DOS by default... mainly for FAT32 support....
Reply 11 of 14, by Amigaz
hehe, you were my "sensei" when it came to this 😁
Reply 12 of 14, by valnar
Have you used UMBPCI.SYS, 386MAX, EMM386 or any other memory manager with PC-DOS? I'd like to know how compatible it is.
Anyway, with DOS 6.22, I have no problem getting 622K - 626K of conventional memory by tweaking it just right, depending on the motherboard.
Reply 13 of 14, by Amigaz
Not using any at the moment since I have enough free conv. memory already since the system stuff is much smaller in PC-DOS and it can be loaded into UMB with DOS DATA=UMB in config.sys
And since I'm mostly running EISA 486 system my conv. memory isn't hogged down with system rom's etc
I don't think QEMM is compatible with PC-DOS
Reply 14 of 14, by l1qu1d
*quote*I've found DOS 7.x to be more than adequate for me. The convenience of FAT32 support is a really big plus*quote* it is actually possible to install a NTFS drive on MS-DOS 6.22, if previously configured.. just as it is on Linux... 😉
