wolf 3d and Blood
First post, by johnb1
Both work fine-However there's a bit of a snag
with Wolf 3d, I have version 1.4( I think) because the L+I+M Code works
but the M+L+S one doesn't and I can't get into the debug menu, and those darn Nazi's keep on kicking my butt
Blood works just dandy, but there's an addon called 'rage against the machine' but the installer won't work under DosBox. You have to have windows ONLY, and that's the only way she'll play. I have a Mac, and am using Boxer, so any help appreciated, as is any DosBox news
thanks
John B
Reply 1 of 3, by leileilol
They removed debug in wolf3d's later versions iirc.
Reply 2 of 3, by franpa
actually you needed to run wolf3d.exe -GOOBERS
to get debug mode in later versions IIRC.
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 3 of 3, by Kerr Avon
Sorry, but all I can suggest is the obvious; install the Rage Against the Machine pack on a Windows system, and copy the files across to your Mac.
I hope that works for you.
