First post, by akula65
SKARDAVNELNATE has noted that the CD-ROMs of Descent for DOS included in the Descent I and II: The Definitive Collection package that are labeled CD-H95-700-0 cannot be upgraded to Version 1.5 using the official Interplay Version 1.4a=>1.5 patch. Using information provided by SKARDAVNELNATE, I have created an "alignment" patch that can be used to convert this particular Registered/Retail version into one which can be upgraded using the official Interplay Version 1.4a=> 1.5 patch.
File info is as follows:
File size: 587608 bytes
MD5: 20d3ba79ca7ad87921257eb9e4a9f788
SHA1: 8b9b7661681be3d5af8ca4b77f57d5e9b4a066e4
    D14PAT10.ZIP
    573.84 KiB
    585 downloads
    Descent V. 1.4a Alignment Patch for CD-H95-700-0
Reply 3 of 4, by Nilex
The stuff you can find on the internetz... Thanks a lot for this patch.
Special commendations for the uber detailed TXT inside.
Same goes for that one of yours as well: Descent Version 1.5 Patch Fix, but alas I needed this one.
