Alias
First post, by EMJ
I used to have aliases to commands in old DOS, I don't find the way to do it under DOSBOX.
I tried an old program called DOSEDIT but it doesn't work under DOSBOX.
Can you recommend a free utility that does alias under DOSBOX, or any way to do it?
Thanks
Reply 1 of 5, by wd
Rank DOSBox Author
DOSBox Author
Create a batch file that is in the path.
Reply 2 of 5, by EMJ
This is not the same that alias, in an Alias file I can have many commands renamed.
I will need 50 batch files, to rename 50 commands...
Reply 3 of 5, by MiniMax
Rank Moderator
Moderator
There is something called 4DOS that works in DOSBox. Maybe you can define aliases in that?
_________________
Reply 4 of 5, by EMJ
Thanks, I will look for it.
Reply 5 of 5, by EMJ
4dos is very cool, but in order to work with him I need to change all my old batch files.
Do you know something simpler? some small application?
Thanks
