First post, by revenger218
Help, I installed dox box 0.72-win32 and followd this http://www.dosbox.com/wiki/Basic_Setup_and_In … ation_of_DosBox
but when i tried to run the setup exe of my game with dos it said (this program must be run under win32) and iam new to dos but that confused me as hell becuse it is dos win32 so can sombudy please tell me how to fix it???? 😕 😢 😕
Reply 1 of 5, by MiniMax
Rank Moderator
Moderator
Your program is a Windows program, not a DOS program.
Better luck with the next one.
_________________
Reply 2 of 5, by revenger218
so you mean i did not download the right one?
DOSBox0.72-win32-installer.exe
Reply 3 of 5, by MiniMax
Rank Moderator
Moderator
Your setup-program is a Windows program.
Reply 4 of 5, by wd
Rank DOSBox Author
DOSBox Author
The version of DOSBox that you're searching is called WINDOWS and you
can buy it at microsoft.com
Reply 5 of 5, by eL_PuSHeR
DOSBox is only meant for running MS-DOS applications. You are trying to run a WINDOWS application.
You must use Microsoft's WINDOWS.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
