SC8500 sound card - what does it do?
Reply 96 of 99, by Predator99
elianda wrote on 2017-08-01, 21:57:
FGB wrote:
SC8000 V 3.31: (maybe something like "Maxi Sound 32 PnP" - Gallant / Guillemot made [...] Drivers are badly needed for both of t […]
Drivers are badly needed for both of the cards but it seems impossible to find them.
Hmm I guess you already tried those: ftp://retronn.de/driver/guillemot_ftp/sound/1632PNP/ ?
Works...thank you! Just gave my SC8000 V3.31 I received recently a quick test and the CS4232C.EXE did the job under DOS.
Tested with
- Populous Adlib
- GODS LAPC1
- Warcraft 2 General Midi and Soundblaster for Digital out
340.87 KiB
32pnonly.zip
564.11 KiB
95 downloads
Reply 97 of 99, by MaxiSound
Hi guys, i complete this thread about the SC8000 V 3.2. This card is a Guillemot Maxi Sound 32 Wave FX Non PNP (NO PNP), so, the drivers and manuals of the maxi sound 32 post in the section Drivers doesn't work. There is an option for RAM and you need also a software to use it (MAXI MEMORY).
I post here the drivers ans manuals (in french) and an pdf for the jumpers assignments on the card.
The dos drivers maxid.sys is neccesary to initalize the card. Under Windows 9.x, copy the files in DSound directory to the windows system. Under DOS, you may use Sound Blaster compatibility or Roland (I post Two examples of sound with Monkey Island 2).
Many thanks!
Reply 98 of 99, by MaxiSound
I post here the links for the manual for the Maxi Memory Software to use with the SC-8000 V3.2. (In french)
I have also the Sound Impression and Cakewalk Express tu use under Windows 3.x-9x but i don't know if is legal.
Enjoy.
    Maxi Memory-FR-Part 3.pdf
    1.78 MiB
    101 downloads
    Maxi Memory Part 3
    Maxi Memory-FR-Part 2.pdf
    1.94 MiB
    104 downloads
    Maxi Memory Part 2
    Maxi Memory-FR-Part 1.pdf
    1.59 MiB
    113 downloads
    Maxi Memory Part 1
