full throttle
First post, by milner
i was wondering if someone can help me to get this game working on Vista, i have used dosbox and installed it fine but when i try to run it it says i need to enter the cd.
I have created a directory in the c drive and copied all the files off the cd into this like the tutorial says but i still cant get it to run.
I'm new to this so any help would be very much appreciated.
thanks
Reply 1 of 3, by MiniMax
Rank Moderator
Moderator
Read my 60 Seconds Guide to DOSBox (and don't just read it - follow it too).
If that doesn't help, come back with details on how you mounted your C and D drives, how you did the install, how you configured sound, music etc.
Reading the aptly named README file will be a good idea too.
_________________
Reply 2 of 3, by milner
thank you very much, i need to use the find function better!
Ive managed to get it up and working thanks to your FAQ you linked me too.
Reply 3 of 3, by filipetolhuizen
SCUMMVM is also an excellent choice to run point and click adventures.
