First post, by Cosmic M
Is this the correct place to request games? If so, id like for there to be support for The Incredible Toon Machine.
Incredible Machine 1 and 2 are supported if that helps at all, when i tried running the installer through DOSBox on my vista x64 machine and it just said that it isnt supported in this version of windows.
Any chance it can happan?
Reply 1 of 7, by MiniMax
Rank Moderator
Moderator
Read my 60 Seconds Guide to DOSBox (and don't just read it - follow it too).
If that doesn't help, come back with details on how you mounted your C and D drives, how you did the install, how you configured sound, music etc.
Reading the aptly named README file will be a good idea too.
_________________
Reply 2 of 7, by Cosmic M
I read that.
Other games that are on your supported list work fine, this is not on the list and does not when using the same method.
What i am asking is if you guys can somehow make this particular game supported/compatible with dosbox.
Reply 3 of 7, by ripsaw8080
Rank DOSBox Author
DOSBox Author
According to Mobygames, The Incredible Toon Machine is a Windows game. You can install Windows 3.x in DOSBox using guides available in these forums, and then you might be able to install and run the game using Windows within DOSBox.
There is a DOS version of the game called Sid & Al's Incredible Toons, which can be run directly in DOSBox without having to install Windows 3.x
Reply 4 of 7, by eL_PuSHeR
[OP's topic title changed to something more descriptive]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 5 of 7, by MiniMax
Rank Moderator
Moderator
You fail...
MiniMax wrote:
If that doesn't help, come back with details on how you mounted your C and D drives, (...)
You did not do that. You fail.
Cosmic M wrote:
(...) it just said that it isnt supported in this version of windows.
I doubt very much that that is the exact error message. Again, you fail.
_________________
Reply 6 of 7, by collector
The exact message would be "This program must be run under Microsoft Windows."
Reply 7 of 7, by leileilol
Everything's ruined under Microsoft Windows.
Since you're using Vista X64 your only choices are:
- install Windows 3.1 in DOSBox
- install a 32-bit Windows operating system, dual-boot
- WINE it up in linux
long live PCem
