First post, by DOSman
Sound is all pitchy and garbled with Battle Chess (1988) & (1989). I read the FAQ in readme and tried reconfiging dosbox.conf but that didnt do anything and I must confess I have no idea really. I have XP Pro SP3, Intel Core 2 Duo, 2G RAM, SB Audigy 4, using dosbox 0.72.
Reply 1 of 11, by ripsaw8080
Rank DOSBox Author
DOSBox Author
I think it only uses the PC speaker, and increasing the sample rates can improve the quality of the sound. For example, I use conf settings of rate=48000 (mixer section) and pcrate=48000 (speaker section) with my Audigy 2 ZX. Generally speaking, a higher sample rate should sound better, but 48khz might be as ideal for you as it is for me. Not sure about the Audigy 4, but the older Audigys have their DSPs locked at 48khz and do horrible up/down-sampling in hardware to achieve that rate internally; so feeding them 48khz avoids the additional quantization noise caused by their poor sample rate conversion. I read that the X-FI cards now have good quality rate conversions done by the DSP, but again I'm not sure if the Audigy 4 has the same issue as the older models. If changing the speaker sample rates works out well, you might want to also increase the sample rates on the other sound devices as well.
Reply 3 of 11, by ripsaw8080
Rank DOSBox Author
DOSBox Author
I run this game with completely default settings in DOSBox 0.72 and it sounds fine. An easy way to be sure you're using all defaults is to run with no conf file. If your sound is still garbled with default settings, check and make sure you don't have high CPU utilization from some background app on your system. Lastly, you can try capturing a bit of what you're hearing with ctrl-F6 and attach that to a post; maybe it will give a clue to the problem.
Reply 5 of 11, by ADDiCT
Did some quick tests with the game.
Latest Gulizoka build with my own custom config (works fine with all games i'm playing usually): garbled sound, just like DOSman's example
Official 0.72 without a .conf (only mounting drives): garbled sound, maybe a bit different from the example
ripsaw8080, what do you mean by "completely default settings"? Are you sure you've used the official 0.72 for testing?
Reply 7 of 11, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The attached captures were made with official DOSBox 0.72 for Win32 using no conf file, meaning all default settings. I did a bit of the opening music, and also a Queen capturing a Knight (changed the board to set that up quickly). Although the PCM sfx isn't great quality, it's typical for speaker, and what I captured doesn't seem garbled to me.
I'm also attaching a screenshot of the title screen to compare and make sure we're all talking about the same game. This is the version that Interplay has available for download on their site.
    bc_sound.zip
    270.3 KiB
    258 downloads
    Title Screen music & Queen capturing Knight
    12.37 KiB
    Battle Chess VGA Title Screen
Reply 9 of 11, by ADDiCT
Yepp, the version i've tested is less colourful (EGA) & says "Copyright 1988" in the title screen. wd, do you know the original game? Did it really sound that bad? I've never played any of the early BC's.
Reply 11 of 11, by DOSman
Well, thanks for clearing this up guys. Shame, I was expecting bone crushing sfx like one review claimed, though they were talking about the PC version. Anyway, I now play the NES version on my DS.
