First post, by Amigaz
Has anyone managed to get a Gravis Ultrasound PnP and AWE32 PnP living happily together in a pure DOS enviroment?
I just tried this with my Gus PnP (rev 3) and AWE32 CT3980.
I made a multi config boot so I either init the AWE or GUS
The AWE32 seem to work even though the CTCM spits out some error message but both FM, dig. sound and AWE Midi synth works
But the Gus init software spits out a message it can't find the card
Reply 1 of 18, by Malik
Have you used the CTCU, the dos utility to assign the resources to these cards?
Reply 2 of 18, by Amigaz
Of course
Reply 3 of 18, by rumbadumba
I only removed my GUS PnP and packed it away this morning, but it was working in a dual boot 95/Dos 5.02 system with an SB Pro 2. The files were a bit of a mess because Win 95 and DOS were on different hd's and I changed the bios settings when rebooting to a different OS. And the GUS software was a hassle to setup and I ended up with things cross-referenced [C: and D: mixed up].
However, here is what I think I had in my working GUS PnP configuration:
autoexec.bat contains:
@SET ULTRADIR=C:\ULTRASND
@C:\ULTRASND\ULTRINIT.EXE -dj
SET INTERWAVE=C:\GRAVIS\ULTRASND\IW.INI
SET IWDIR = C:\GRAVIS\ULTRASND
PATH= ... C:\ULTRASND; C:\GRAVIS\ULTRASND
I have a feeling the first two lines above were left over from an GUS ACE install.
config.sys contains:
device=C:\GRAVIS\ULTRANSD\IWINIT.EXE id=GRV00001
IW.INI contains amongst a lot else:
[vendor grav_org]
default.fff=c:\ultrasnd\midi\
For sound in heretic I also need to type:
SET ULTRASND=220,5,7,11,5
Maybe not all this is relevant [as it may relate to other things I was trying, and not be necessary] but it might help you work out what you need to do.
If you have no joy with this I'll dig out my PnP and test it again.
Edit: Also noticed my Heretic is setup up for Gravis as sound card but General MIDI @330 for music.
Reply 4 of 18, by Amigaz
rumbadumba wrote:
I only removed my GUS PnP and packed it away this morning, but it was working in a dual boot 95/Dos 5.02 system with an SB Pro 2 […]
[vendor grav_org]
Yes, of course it works alongside other non PnP cards as the Sb Pro
Have another Gus PnP card living next to an AWE32 non PnP, Ensoniq Soundscape, Roland Super MPU
Reply 5 of 18, by rumbadumba
Mine was working fine alongside an EWS64XL [which is plug and play] as well as an SB Pro2.
Reply 6 of 18, by Amigaz
In a PnP motherboard?
Reply 7 of 18, by rumbadumba
Since Win95 detects the pnp cards, I guess so. Motherboard is a Gigabyte GA-686BX.
Sometimes using iwinit -hunt helps. But sometimes not.
I did go through a period when iwinit couldn't find the card - can't remember what resolved this - it may have been a resource conflict.
Reply 8 of 18, by aleksej
GUS PnP v1.0 and AWE64 Gold CT4390 living happily together in one of my PC's. There is MS-DOS 6.22, Windows 98SE and Windows XP installed. Both cards working simultaneously in all three OS'es without any problems.
Reply 9 of 18, by Amigaz
Any chance you can tell how how you got it working? 😀
Reply 10 of 18, by 5u3
Here is my SB AWE32 CT3980 + GUS PnP setup:
Note: I've used the "GUS PnP EEPROM tool" (download here) to deactivate any GUS PnP resources except the base I/O address, one IRQ and one DMA. This is not absolutely necessary, but makes the configuration a lot easier.
Relevant CONFIG.SYS entries:
None.
Relevant AUTOEXEC.BAT entries:
SET BLASTER=A220 I5 D1 H5 P330 E620 T6
SET CTCM=C:\SB\CTCM
SET SOUND=C:\SB
SET INTERWAVE=C:\GUS\IW.INI
SET IWDIR=C:\GUS
SET ULTRASND=240,3,3,7,7
SET ULTRADIR=C:\GUS
C:\SB\CTCM\CTCM.EXE
C:\SB\AWEUITL.COM /S
C:\GUS\IWINIT.EXE
Relevant entries in CTPNP.CFG
[SB16]
Disable=0
Port0=220
Port1=330
Port2=388
Irq0=5
Dma0=1
Dma1=5
[IDE]
Disable=1
[GAMEPORT]
Disable=0
Port0=200
[AWE]
Disable=0
Port0=620
Port1=a20
Port2=e20
Relevant entries in IW.INI
[setup 0]
SynthBase=240
CodecBase=34C
CDBase=0
ATAPIBase=0
MpuBase=0
AdlibBase=0
GamePort=0
IRQ1=7
IRQ2=7
CDIRQ=0
MPUIRQ=0
SBIRQ=0
DMA1=3
DMA2=3
CDDMA=0
I do not use the GUS PnP under Windows (this opens another can of worms).
The gameport and AdLib port are assigned to the AWE card. Also, I do not use any GUS emulation programs except the MEGAEM MIDI emulation.
EDIT: I forgot the BIOS settings:
PnP OS Installed: No
All PCI IRQs (video, network, USB) assigned manually.
All ISA IRQs/DMAs/Memory blocks set to None/ICU.
Hope this helps...
Reply 11 of 18, by Amigaz
5u3 wrote:
Here is my SB AWE32 CT3980 + GUS PnP setup: […]
None.
SET CTCM=C:\SB\CTCM
SET SOUND=C:\SB
SET IWDIR=C:\GUS
SET ULTRADIR=C:\GUS
C:\SB\CTCM\CTCM.EXE
C:\GUS\IWINIT.EXE
[SB16]
Disable=0
Port0=220
Port1=330
Port2=388
Irq0=5
Dma0=1
Dma1=5
[IDE]
Disable=1
[GAMEPORT]
Disable=0
Port0=200
[AWE]
Disable=0
Port0=620
Port1=a20
Port2=e20
[setup 0]
SynthBase=240
CodecBase=34C
CDBase=0
ATAPIBase=0
MpuBase=0
AdlibBase=0
GamePort=0
IRQ1=7
IRQ2=7
CDIRQ=0
MPUIRQ=0
SBIRQ=0
DMA1=3
DMA2=3
CDDMA=0
Hope this helps...
The weird thing is that I've done exactly what you haver done (exact the same resource settings) but the Gus PnP init says it cannot find my card?
Mauybe time to upgrade my 0306 bios version..
Reply 12 of 18, by 5u3
Ah, you're trying to get them running on the PVI-486SP3? That's a tough one, because the BIOS is from the days when PnP was only mentioned in connection with selected curse words. 😜
I've found no option to prevent the board from assigning seemingly random resources to ISA-PnP cards when booting, which is very counterproductive when these PnP cards are supposed use certain pre-defined resources.
In theory it should be possible to get both of the cards running by editing the PnP resource profiles stored on the EEPROMs of the cards, but apparently the PVI-486SP3 BIOS ignores these profiles and they always end up being given the wrong resources or no resources at all.
On my P5A board the two PnP sound cards can coexist in peace (after much haggling and negotiating), but on the 486 board I've given up and resorted to non-PnP cards (CT3900 + GUS classic).
Reply 13 of 18, by Amigaz
5u3 wrote:
Ah, you're trying to get them running on the PVI-486SP3? That's a tough one, because the BIOS is from the days when PnP was only […]
Yeah, I'm trying it on my PV/I 486SP3 mobo....it's like you said in a previous port about it: "it's plug'n'play bios is a joke" 😁
I'm going to stick in a CT2760 or CT3900 instead 😀
Reply 14 of 18, by aleksej
Here is my setup:
Ofcource, GUS PnP "emasculated" by IWEEPROM utility. One port (340), one IRQ (11) and two DMA (6,7) - that's what i keep on.
Now, here is relevant fragments of my CONFIG.SYS and AUTOEXEC.BAT files with different sections for different GUS IRQ - 11 or 7 (for stupid games like Duke Nukem 3D and etc. which doesn't work with GUS on IRQ higher than 7).
CONFIG.SYS
[MENU]
SUBMENU=GUSIRQ11, Ultrasound on IRQ11
SUBMENU=GUSIRQ7, Ultrasound on IRQ7
MENUDEFAULT=GUSIRQ11,10
[GUSIRQ11]
blablabla...
device=c:\ctcm\ctcm.exe
blablabla....
[GUSIRQ7]
include=GUSIRQ11
blablabla...
AUTOEXEC.BAT
blablabla...
SET PATH=...C:\ULTRASND;C:\AWE32;...
blablabla...
REM ========= AWE32 initialization =========
SET MIDI=SYNTH:1 MAP:E MODE:0
SET SOUND=C:\AWE32
SET CTCM=C:\CTCM
c:\awe32\diagnose.exe /s
c:\awe32\aweutil.com /s
c:\awe32\mixerset.exe /p /q
blablabla...
GOTO %CONFIG%
:GUSIRQ11
blablabla...
REM == Ultrasound initialization on IRQ11 ==
SET INTERWAVE=C:\ULTRASND\IW.INI
SET IWDIR=C:\ULTRASND
SET ULTRASND=240,6,7,11,11
SET ULTRA16=34C,7,11,1,0
c:\ultrasnd\iwinit.exe
blablabla...
GOTO DONE
:GUSIRQ7
blablabla...
REM == Ultrasound initialization on IRQ7 ==
SET INTERWAVE=C:\ULTRASND\IWI7.INI
SET ULTRASND=240,6,7,7,7
SET ULTRA16=34C,7,7,1,0
blablabla...
GOTO DONE
:DONE
blablabla...
Now, last section of IW.INI (IWI7.INI)
[setup 0]
mode=pnp
GPusage=IRQ
revision=B0
csn=1
pnprdp=20b
UseDma=true
SynthBase=240
CodecBase=34c
AdLibBase=0
GamePort=0
ATAPIBase=0
DMA1=6
DMA2=7
IRQ1=11
IRQ2=0
CDBase=0
CDIRQ=0
CDDMA=4
SBIRQ=0
SBDMA=1
MpuBase=0
MPUIRQ=0
vendor_id=GRV0001
effects=on
winrdp=277
dosrdp=20b
config=0
ptelar=0
Here is only difference - IRQ1 value (11 or 7).
Thats all.
Reply 15 of 18, by Amigaz
aleksej wrote:
Here is my setup: […]
Here is my setup:
CONFIG.SYS
[MENU]
[GUSIRQ11]
blablabla...
blablabla....
[GUSIRQ7]
include=GUSIRQ11
blablabla...
AUTOEXEC.BAT
blablabla...
blablabla...
SET SOUND=C:\AWE32
SET CTCM=C:\CTCM
blablabla...
GOTO %CONFIG%
:GUSIRQ11
blablabla...
blablabla...
GOTO DONE
:GUSIRQ7
blablabla...
blablabla...
GOTO DONE
:DONE
blablabla...
[setup 0]
mode=pnp
GPusage=IRQ
revision=B0
csn=1
pnprdp=20b
UseDma=true
SynthBase=240
CodecBase=34c
AdLibBase=0
GamePort=0
ATAPIBase=0
DMA1=6
DMA2=7
IRQ1=11
IRQ2=0
CDBase=0
CDIRQ=0
CDDMA=4
SBIRQ=0
SBDMA=1
MpuBase=0
MPUIRQ=0
vendor_id=GRV0001
effects=on
winrdp=277
dosrdp=20b
config=0
ptelar=0
Thats all.
Thanks
Might help me if I use the cards in a real PnP system not in my "proto PnP" motherboard Asus PV/I 486SP3 which can only handle one PnP card 😵
Reply 16 of 18, by Cloudschatze
Amigaz wrote:
The AWE32 seem to work even though the CTCM spits out some error message but both FM, dig. sound and AWE Midi synth works...
What a happy happenstance. I recently encountered this same issue (Creative CT2940 + GUSPnP).
These errors appear to be the result of CTCM trying to assign resources to the GUS. You'll find that CTCU can even be used to configure the Ultrasound, which shouldn't be possible...
The solution that resolved these issues for me was to upgrade the GUS' EEPROM, using the "Gravis.rom" image found in the P20DISK3.ZIP archive.
Reply 17 of 18, by Amigaz
Cloudschatze wrote:
What a happy happenstance. I recently encountered this same issue (Creative CT2940 + GUSPnP). […]
Aha! thanks
might try this if I want to throw on the Awe card again in this machine...but right now it sits rotting in te basement of my new appartment
Reply 18 of 18, by elianda
There is a way, but it's different.
If the BIOS assigns random ressources, simply flush the ressources again (as the PC does on reboot) and then reconfigure it as usual (as if you would had a PnP BIOS with PnP aware OS enabled, thus not configuring any ressources on non-boot relevant ISA cards).
To flush ressources again use the isa-pnptools from linux (the DOS version ofcourse).
There is also a link to an archive that includes the dos compiled binaries:
http://www.roestock.demon.co.uk/isapnptools/
