First post, by Unregistered
Hi folks!
First of all, VDMSound is a great program! I noticed, however, some quirks on my machine when running certain VESA DOS games using VDMSound Launchpad.
An example is Mission Critical, which is running fine from a graphical point of view (letting the stuttering of speech aside) - but as soon as I return to desktop, the screen is totally garbled with stripes and you can produce new patterns moving the mouse around. I can even start applications like IE - when opening, the window is only slightly garbled but things change during mouse movement. The Desktop, however, always remains totally garbled.
I presume the games are doing some stuff with registers/memory ranges causing problems with my graphics card driver (Catalyst 3.6, 3.4 before).
Sadly, I couldn't find another post describing a similiar problem.
Some ideas? I'm planning to try VDMSound 2.1.0 Beta and NOLFB next (currently VDMSound 2.0.4 latest version/latest launchpad).
Sorry for loading the following listing onto you, but that seemed to be the easiest way for system info (Mobo ASUS P4PE, Sapphire Radeon 9500 Pro w/ device id changed BIOS):
System Information
Time of this report: 8/26/2003, 00:48:06
Machine name: MMEPC
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 1 (2600.xpsp2.030527-2026)
Language: German (Regional Setting: German)
System Manufacturer: n/a
System Model: n/a
BIOS: Award Modular BIOS v6.0
Processor: Intel(R) Pentium(R) 4 CPU 2.40GHz
Memory: 512MB RAM
Page File: 238MB used, 1008MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0b (4.09.0000.0902)
DX Setup Parameters: None
DxDiag Version: 5.03.0001.0902 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: The registry information for the DirectPlay application 'Star Wars JK II Jedi Outcast' is missing or damaged. You should reinstall that application.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: RADEON 9700 PRO
Manufacturer: ATI Technologies Inc.
Chip type: RADEON 9700 AGP (0x4E44)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_4E44&SUBSYS_00021002&REV_00
Display Memory: 128.0 MB
Current Mode: 1024 x 768 (32 bit) (85Hz)
Monitor: Plug und Play-Monitor
Monitor Max Res: 1600,1200
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6368 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 6/25/2003 17:40:44, 302592 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: Nicht zutreffend
Mini VDD: ati2mtag.sys
Mini VDD Date: 6/25/2003 17:40:12, 587264 bytes
Device Identifier: {D7B71EE2-0D04-11CF-526B-0820A1C2CB35}
Vendor ID: 0x1002
Device ID: 0x4E44
SubSys ID: 0x00021002
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=DeinterlaceTech_BOBVerticalStretch
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=DeinterlaceTech_BOBVerticalStretch
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,1) Caps=DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=DeinterlaceTech_BOBVerticalStretch
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=DeinterlaceTech_BOBVerticalStretch
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(IMC1,0x31434d49) Frames(Prev/Fwd/Back)=(0,0,1) Caps=DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,0x31434d49) Frames(Prev/Fwd/Back)=(0,0,0) Caps=DeinterlaceTech_BOBVerticalStretch
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(IMC2,0x32434d49) Frames(Prev/Fwd/Back)=(0,0,1) Caps=DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,0x32434d49) Frames(Prev/Fwd/Back)=(0,0,0) Caps=DeinterlaceTech_BOBVerticalStretch
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(IMC3,0x33434d49) Frames(Prev/Fwd/Back)=(0,0,1) Caps=DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,0x33434d49) Frames(Prev/Fwd/Back)=(0,0,0) Caps=DeinterlaceTech_BOBVerticalStretch
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(IMC4,0x34434d49) Frames(Prev/Fwd/Back)=(0,0,1) Caps=DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,0x34434d49) Frames(Prev/Fwd/Back)=(0,0,0) Caps=DeinterlaceTech_BOBVerticalStretch
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(S340,0x30343353) Frames(Prev/Fwd/Back)=(0,0,1) Caps=DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,0x30343353) Frames(Prev/Fwd/Back)=(0,0,0) Caps=DeinterlaceTech_BOBVerticalStretch
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(S342,0x32343353) Frames(Prev/Fwd/Back)=(0,0,1) Caps=DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,0x32343353) Frames(Prev/Fwd/Back)=(0,0,0) Caps=DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: SB Live! Audio [9400]
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1102&DEV_0002&SUBSYS_80401102&REV_08
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ctaud2k.sys
Driver Version: 5.12.0001.0252 (English)
WHQL Logo'd: Yes
Date and Size: 7/19/2002 10:47:52, 837548 bytes
Other Files:
Driver Provider: Creative
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 4000, 191999
Static/Strm HW Mix Bufs: 32, 30
Static/Strm HW 3D Bufs: 32, 30
HW Memory: 0
Voice Management: Yes
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: Enabled
Ports: SB Live! DirectMusic Synthesizer [9400], Hardware (Kernel Mode), Output, DLS, Internal, Default Port
SB Live! Audio [9400], Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI-Mapper [Emuliert], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Live! Synth A [9400] [Emuliert], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Live! Sw-Synth [9400] [Emuliert], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Live! Synth B [9400] [Emuliert], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Live! MIDI-Anschluss [9400] [Emuliert], Hardware (Not Kernel Mode), Output, No DLS, External
Microsoft GS Wavetable SW Synth [Emuliert], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Live! MIDI-Anschluss [9400] [Emuliert], Hardware (Not Kernel Mode), Input, No DLS, External
Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Maus
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Tastatur
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Microsoft SideWinder 3D Pro
Attached: 0
Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x0F1F
FF Driver: n/a
Device Name: SideWinder Game Voice
Attached: 1
Controller ID: 0x11
Vendor/Product ID: 0x045E, 0x003B
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB-Root-Hub
| Vendor/Product ID: 0x8086, 0x24C7
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 7/3/2003 17:52:58, 53120 bytes
| Driver: usbd.sys, 8/23/2001 14:00:00, 4736 bytes
+-+ Standard-USB-Hub
| | Vendor/Product ID: 0x03EB, 0x3301
| | Matching Device ID: usb\class_09
| | Service: usbhub
Gameport Devices
+ Intel(R) 82801DB PCI Bridge - 244E
| Matching Device ID: pci\ven_8086&dev_244e
| Service: pci
| Driver: pci.sys, 8/29/2002 03:41:44, 62976 bytes
+-+ Creative Game Port
| | Matching Device ID: pci\ven_1102&dev_7002&subsys_00201102
| | Service: gameenum
| | Driver: gameenum.sys, 8/29/2002 01:32:44, 9856 bytes
| +-+ Microsoft SideWinder (Automatische Erkennung)
| | | Matching Device ID: gameport\sidewindergamecontroller
| | | Service: msgame
| | | Driver: msgame.sys, 8/17/2001 15:02:40, 35200 bytes
| | | Driver: hidparse.sys, 8/23/2001 14:00:00, 23680 bytes
| | | Driver: hid.dll, 8/23/2001 14:00:00, 22528 bytes
| | | Driver: sw_effct.dll, 8/18/2001 05:54:26, 41472 bytes
| | | Driver: sw_wheel.dll, 8/18/2001 05:54:26, 53760 bytes
| | | Driver: hidclass.sys, 8/29/2002 01:32:42, 34560 bytes
| | +-+ HID-konformer Gamecontroller
| | | | Matching Device ID: hid_device_system_game
PS/2 Devices
+ Standardtastatur (101/102 Tasten) oder Microsoft Natural Keyboard (PS/2)
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/29/2002 03:22:04, 51584 bytes
| Driver: kbdclass.sys, 8/29/2002 03:27:50, 24064 bytes
+ Terminalserver-Tastaturtreiber
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/29/2002 03:43:46, 38024 bytes
+ Microsoft PS/2 Port Mouse (IntelliPoint)
| Matching Device ID: *pnp0f13
| Upper Filters: IPFilter
| Service: i8042prt
| Driver: mouclass.sys, 8/29/2002 03:38:58, 22528 bytes
| Driver: ipfilter.sys, 4/11/2002 10:47:52, 11136 bytes
| Driver: msmscoin.dll, 4/11/2002 10:47:52, 49152 bytes
+ Terminalserver-Maustreiber
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 TCP/IP Service Provider (Network Simulator) - Registry: OK, File: D:\DXSDK\Bin\DXUtils\dp8sim.dll (4.09.0000.0900)
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0000.0900)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0000.0900)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)
DirectPlay Voice Wizard Tests: Full Duplex: Passed, Half Duplex: Passed, Mic: Failed gracefully
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 TCP/IP Service Provider (Network Simulator): LAN-Verbindung - IPv4 -
DirectPlay8 Modem Service Provider: Bluelet Modem #3
DirectPlay8 Modem Service Provider: Bluelet Modem #2
DirectPlay8 Modem Service Provider: Bluelet Modem #1
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM2
DirectPlay8 TCP/IP Service Provider: LAN-Verbindung - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
SimplePeer (DX8) - Registry: OK, ExeFile: SimplePeer.exe (4.09.0000.0900) LauncherFile: SimplePeer.exe (4.09.0000.0900)
StagedPeer (DX8) - Registry: OK, ExeFile: StagedPeer.exe (4.09.0000.0900) LauncherFile: StagedPeer.exe (4.09.0000.0900)
ChatPeer (DX8) - Registry: OK, ExeFile: ChatPeer.exe (4.09.0000.0900) LauncherFile: ChatPeer.exe (4.09.0000.0900)
VoicePosition (DX8) - Registry: OK, ExeFile: VoicePosition.exe (4.09.0000.0900) LauncherFile: VoicePosition.exe (4.09.0000.0900)
VoiceGroup (DX8) - Registry: OK, ExeFile: VoiceGroup.exe (4.09.0000.0900) LauncherFile: VoiceGroup.exe (4.09.0000.0900)
DataRelay (DX8) - Registry: OK, ExeFile: DataRelay.exe (4.09.0000.0900) LauncherFile: DataRelay.exe (4.09.0000.0900)
VoiceConnect (DX8) - Registry: OK, ExeFile: VoiceConnect.exe (4.09.0000.0900) LauncherFile: VoiceConnect.exe (4.09.0000.0900)
Jedi Knight 1.0 (DX7) - Registry: OK, ExeFile: Jk.exe (1.00.0001.0000)
Sacrifice (DX7) - Registry: OK, ExeFile: sacrifice.exe (1.00.0000.0000)
Sid Meier's Alpha Centauri (DX7) - Registry: OK, ExeFile: terran.exe ()
Star Wars Galactic Battlegrounds (DX7) - Registry: OK, ExeFile: battlegrounds.exe (1.00.0000.0000)
Star Wars Galactic Battlegrounds: Clone Campaigns (DX7) - Registry: OK, ExeFile: battlegrounds_x1.exe (1.01.0000.0000)
Star Wars JK II Jedi Outcast (DX7) - Registry: Error, ExeFile: jk2mp.exe (<Fehlende Datei>)
Startopia (DX7) - Registry: OK, ExeFile: Startopia.exe (<Fehlende Datei>)
STNW (DX7) - Registry: OK, ExeFile: STNW.EXE ()
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 1.6 GB
Total Space: 10.2 GB
File System: NTFS
Model: Promise 1X2 Mirror/RAID1 SCSI Disk Device
Drive: D:
Free Space: 3.5 GB
Total Space: 11.3 GB
File System: NTFS
Drive: E:
Free Space: 0.3 GB
Total Space: 5.1 GB
File System: NTFS
Drive: F:
Free Space: 1.8 GB
Total Space: 16.6 GB
File System: NTFS
Drive: T:
Free Space: 0.5 GB
Total Space: 2.5 GB
File System: NTFS
Drive: V:
Free Space: 3.7 GB
Total Space: 5.8 GB
File System: NTFS
Drive: W:
Free Space: 1.6 GB
Total Space: 5.9 GB
File System: NTFS
Drive: X:
Free Space: 79.0 GB
Total Space: 117.2 GB
File System: NTFS
Model: Maxtor 5000DV v1.00.00 IEEE 1394 SBP2 Device
Drive: Z:
Free Space: 1.2 GB
Total Space: 2.0 GB
File System: NTFS
System Devices
Name: Intel(R) 82845G/GL/GE/PE/GV Processor to AGP Controller - 2561
Device ID: PCI\VEN_8086&DEV_2561&SUBSYS_00000000&REV_02\3&61AAA01&0&08
Driver: C:\WINDOWS\System32\DRIVERS\AGP440.SYS, 5.01.2600.0000 (English), 8/17/2001 13:58:00, 25472 bytes
Name: Intel(R) 82845G/GL/GE/PE/GV Processor to I/O Controller - 2560
Device ID: PCI\VEN_8086&DEV_2560&SUBSYS_00000000&REV_02\3&61AAA01&0&00
Driver: n/a
Name: Intel(r) 82801DB/DBM USB 2.0 erweiterter Hostcontroller - 24CD
Device ID: PCI\VEN_8086&DEV_24CD&SUBSYS_80891043&REV_02\3&61AAA01&0&EF
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.1243 (English), 7/3/2003 17:50:46, 25216 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.1243 (English), 7/3/2003 17:49:30, 138752 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.1243 (English), 7/3/2003 17:52:58, 53120 bytes
Driver: C:\WINDOWS\System32\hccoin.dll, 5.01.2600.1243 (English), 7/3/2003 17:50:12, 5632 bytes
Driver: C:\WINDOWS\System32\usbui.dll, 5.01.2600.0000 (German), 8/18/2001 04:54:32, 70144 bytes
Name: Intel(R) 82801DB Ultra ATA Controller
Device ID: PCI\VEN_8086&DEV_24CB&SUBSYS_80891043&REV_02\3&61AAA01&0&F9
Driver: C:\WINDOWS\System32\DRIVERS\IdeChnDr.sys, 2.03.0000.2160 (English), 10/15/2002 00:00:00, 101431 bytes
Driver: C:\WINDOWS\System32\DRIVERS\IdeBusDr.sys, 2.03.0000.2160 (English), 10/15/2002 00:00:00, 13891 bytes
Driver: C:\WINDOWS\System32\IPrtCnst.dll, 2.03.0000.2160 (English), 10/15/2002 00:00:00, 44875 bytes
Name: Intel(R) 82801DB/DBM USB Universal Host Controller - 24C7
Device ID: PCI\VEN_8086&DEV_24C7&SUBSYS_80891043&REV_02\3&61AAA01&0&EA
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.1243 (English), 7/3/2003 17:51:46, 19328 bytes
Name: Intel(R) 82801DB/DBM USB Universal Host Controller - 24C4
Device ID: PCI\VEN_8086&DEV_24C4&SUBSYS_80891043&REV_02\3&61AAA01&0&E9
Name: Intel(R) 82801DB/DBM USB Universal Host Controller - 24C2
Device ID: PCI\VEN_8086&DEV_24C2&SUBSYS_80891043&REV_02\3&61AAA01&0&E8
Name: Intel(R) 82801DB LPC Interface Controller - 24C0
Device ID: PCI\VEN_8086&DEV_24C0&SUBSYS_00000000&REV_02\3&61AAA01&0&F8
Driver: C:\WINDOWS\System32\DRIVERS\isapnp.sys, 5.01.2600.0000 (German), 8/18/2001 04:18:44, 36224 bytes
Name: Intel(R) 82801DB PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_82\3&61AAA01&0&F0
Driver: C:\WINDOWS\System32\DRIVERS\pci.sys, 5.01.2600.1106 (German), 8/29/2002 03:41:44, 62976 bytes
Name: Broadcom NetXtreme Gigabit Ethernet
Device ID: PCI\VEN_14E4&DEV_16A6&SUBSYS_80A91043&REV_02\4&3B90381F&0&28F0
Driver: n/a
Name: VIA OHCI-konformer IEEE 1394-Hostcontroller
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_808A1043&REV_80\4&3B90381F&0&18F0
Driver: C:\WINDOWS\System32\DRIVERS\ohci1394.sys, 5.01.2600.1106 (English), 8/29/2002 01:33:20, 55680 bytes
Driver: C:\WINDOWS\System32\DRIVERS\1394bus.sys, 5.01.2600.1106 (English), 8/29/2002 01:33:20, 50560 bytes
Driver: C:\WINDOWS\System32\DRIVERS\nic1394.sys, 5.01.2600.1106 (English), 8/29/2002 01:33:32, 57984 bytes
Driver: C:\WINDOWS\System32\DRIVERS\arp1394.sys, 5.01.2600.1106 (English), 8/29/2002 01:33:30, 57344 bytes
Driver: C:\WINDOWS\System32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 13:46:40, 6400 bytes
Name: Creative Game Port
Device ID: PCI\VEN_1102&DEV_7002&SUBSYS_00201102&REV_08\4&3B90381F&0&69F0
Driver: C:\WINDOWS\system32\drivers\gameenum.sys, 5.01.2600.1106 (English), 8/29/2002 01:32:44, 9856 bytes
Name: Creative SB Live! Value
Device ID: PCI\VEN_1102&DEV_0002&SUBSYS_80401102&REV_08\4&3B90381F&0&68F0
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.1106 (English), 8/29/2002 01:32:34, 57856 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.1106 (English), 8/29/2002 02:01:00, 134272 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.1164 (German), 1/30/2003 17:55:44, 45056 bytes
Driver: C:\WINDOWS\System32\wdmaud.drv, 5.01.2600.0000 (English), 8/18/2001 04:55:14, 22016 bytes
Driver: C:\WINDOWS\System32\ksuser.dll, 5.03.0000.0900 (German), 12/12/2002 01:14:32, 4096 bytes
Driver: C:\WINDOWS\system32\drivers\ctac32k.sys, 5.12.0001.0245 (English), 7/19/2002 10:46:28, 127948 bytes
Driver: C:\WINDOWS\system32\drivers\ctaud2k.sys, 5.12.0001.0252 (English), 7/19/2002 10:47:52, 837548 bytes
Driver: C:\WINDOWS\system32\drivers\ctoss2k.sys, 5.12.0001.0245 (English), 7/19/2002 10:48:04, 195432 bytes
Driver: C:\WINDOWS\system32\drivers\ctprxy2k.sys, 5.12.0001.0244 (English), 7/19/2002 10:48:08, 11068 bytes
Driver: C:\WINDOWS\system32\drivers\ctsfm2k.sys, 5.12.0001.0140 (English), 7/19/2002 10:48:22, 213860 bytes
Driver: C:\WINDOWS\system32\drivers\emupia2k.sys, 5.12.0001.0244 (English), 7/19/2002 10:48:32, 156604 bytes
Driver: C:\WINDOWS\system32\drivers\ha10kx2k.sys, 5.12.0001.0250 (English), 7/24/2002 13:52:26, 998004 bytes
Driver: C:\WINDOWS\System32\ctdlang.dat, 7/19/2002 11:07:30, 164044 bytes
Driver: C:\WINDOWS\System32\ctstatic.dat, 7/19/2002 10:59:32, 179669 bytes
Driver: C:\WINDOWS\System32\ctdaught.dat, 7/19/2002 10:56:50, 44055 bytes
Driver: C:\WINDOWS\System32\default.ecw, 9/22/1999 23:18:50, 2259067 bytes
Driver: C:\WINDOWS\System32\sfman32.dll, 5.12.0001.0130 (English), 8/17/2001 14:35:46, 36864 bytes
Driver: C:\WINDOWS\System32\a3d.dll, 80.00.0000.0003 (English), 7/19/2002 10:43:06, 65536 bytes
Driver: C:\WINDOWS\System32\ctbasicw.dat, 7/19/2002 11:02:24, 113373 bytes
Driver: C:\WINDOWS\System32\SBLive.ico, 10/22/2001 09:10:28, 4398 bytes
Driver: C:\WINDOWS\System32\Live.bmp, 10/22/2001 09:10:28, 3126 bytes
Name: Hauppauge WinTV 878/9 WDM Aux Driver
Device ID: PCI\VEN_109E&DEV_0878&SUBSYS_13EB0070&REV_11\4&3B90381F&0&51F0
Driver: n/a
Name: Hauppauge WinTV 878/9 WDM Video Driver
Device ID: PCI\VEN_109E&DEV_036E&SUBSYS_13EB0070&REV_11\4&3B90381F&0&50F0
Driver: C:\WINDOWS\System32\stream.sys, 5.03.0000.0900 (German), 12/12/2002 01:14:32, 45696 bytes
Driver: C:\WINDOWS\System32\vfwwdm32.dll, 5.01.2600.1106 (German), 8/29/2002 03:43:32, 50176 bytes
Driver: C:\WINDOWS\System32\msh263.drv, 4.04.0000.3400 (German), 8/29/2002 03:43:44, 286720 bytes
Driver: C:\WINDOWS\System32\iyuv_32.dll, 5.01.2600.0000 (German), 8/18/2001 04:53:46, 45568 bytes
Driver: C:\WINDOWS\System32\msyuv.dll, 5.03.0000.0900 (English), 2/17/2003 10:16:28, 16896 bytes
Driver: C:\WINDOWS\System32\tsbyuv.dll, 5.01.2600.0000 (English), 8/18/2001 04:54:30, 8192 bytes
Name: WinXP Promise FastTrak 376/378 (tm) Controller
Device ID: PCI\VEN_105A&DEV_3376&SUBSYS_809E1043&REV_02\4&3B90381F&0&20F0
Driver: C:\WINDOWS\System32\DRIVERS\Fasttx2k.sys, 1.00.0001.0030 (English), 6/16/2003 20:58:00, 158080 bytes
Driver: C:\WINDOWS\System32\ptipbmf.dll, 1.00.0000.0003 (English), 6/16/2003 11:01:52, 118784 bytes
Name: RADEON 9700 PRO - Secondary
Device ID: PCI\VEN_1002&DEV_4E64&SUBSYS_00031002&REV_00\4&287FE477&0&0108
Driver: C:\WINDOWS\System32\DRIVERS\ati2mtag.sys, 6.14.0010.6368 (German), 6/25/2003 17:40:12, 587264 bytes
Driver: C:\WINDOWS\System32\ati2dvag.dll, 6.14.0010.6368 (English), 6/25/2003 17:40:44, 302592 bytes
Driver: C:\WINDOWS\System32\Ati2mdxx.exe, 4.13.0001.0003 (English), 9/4/2001 16:24:26, 28672 bytes
Driver: C:\WINDOWS\System32\ati3d1ag.dll, 6.14.0010.3844 (English), 6/25/2003 16:24:24, 848640 bytes
Driver: C:\WINDOWS\System32\ati3d2ag.dll, 6.14.0010.3844 (English), 6/25/2003 16:45:30, 1036288 bytes
Driver: C:\WINDOWS\System32\ati3duag.dll, 6.14.0010.0182 (English), 6/25/2003 17:08:56, 1086240 bytes
Driver: C:\WINDOWS\System32\ATIDDC.DLL, 6.14.0010.0004 (English), 6/25/2003 17:24:26, 73728 bytes
Driver: C:\WINDOWS\System32\atitvo32.dll, 6.14.0010.4000 (English), 6/25/2003 16:09:34, 17408 bytes
Driver: C:\WINDOWS\System32\ativcoxx.dll, 6.13.0010.0005 (English), 11/9/2001 11:01:04, 24064 bytes
Driver: C:\WINDOWS\System32\ati2evxx.exe, 6.14.0010.4079 (English), 6/25/2003 17:25:22, 294912 bytes
Driver: C:\WINDOWS\System32\ati2evxx.dll, 6.14.0010.4079 (English), 6/25/2003 17:27:50, 90112 bytes
Driver: C:\WINDOWS\System32\atipdlxx.dll, 6.14.0010.2481 (English), 6/25/2003 17:28:18, 81920 bytes
Driver: C:\WINDOWS\System32\Oemdspif.dll, 6.14.0001.0008 (English), 6/25/2003 17:28:12, 73728 bytes
Driver: C:\WINDOWS\System32\atioglxx.dll, 6.14.0010.3842 (English), 6/25/2003 18:32:54, 4796416 bytes
Driver: C:\WINDOWS\System32\atiiiexx.dll, 6.14.0010.3009 (English), 6/25/2003 20:22:18, 229376 bytes
Device ID: PCI\VEN_1002&DEV_4E44&SUBSYS_00021002&REV_00\4&287FE477&0&0008
DirectX Components
ddraw.dll: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 257536 bytes
ddrawex.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 24064 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 14:00:00 10496 bytes
d3d8.dll: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 1156608 bytes
d3d8thk.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 8192 bytes
d3dref8.dll: 5.03.0000.0900 English Final Retail 12/12/2002 01:14:32 212992 bytes
d3d9.dll: 5.03.0001.0902 German Final Retail 5/30/2003 09:00:02 1613312 bytes
d3dref9.dll: 5.03.0000.0900 English Final Retail 12/12/2002 01:14:32 318976 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 14:00:00 436224 bytes
d3dim700.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 797184 bytes
d3dref.dll: 5.03.0000.0900 English Final Retail 12/12/2002 01:14:32 91136 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 14:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 14:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 14:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 14:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 German Final Retail 8/23/2001 14:00:00 33040 bytes
dplayx.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 217600 bytes
dpmodemx.dll: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 22528 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 14:00:00 42768 bytes
dpwsockx.dll: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 54784 bytes
dplaysvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 28160 bytes
dpnsvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 16896 bytes
dpnet.dll: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 381952 bytes
dpnlobby.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072 bytes
dpnaddr.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072 bytes
dpvoice.dll: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 205312 bytes
dpvsetup.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 80896 bytes
dpvvox.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 112128 bytes
dpvacm.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 19968 bytes
dpnhpast.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02 32768 bytes
dpnhupnp.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02 68096 bytes
dpserial.dll: 5.00.2134.0001 German Final Retail 8/23/2001 14:00:00 54032 bytes
dinput.dll: 5.01.2600.1106 German Final Retail 8/29/2002 03:40:00 156160 bytes
dinput8.dll: 5.01.2600.1106 German Final Retail 8/29/2002 03:40:00 173568 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 14:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 German Final Retail 8/23/2001 05:00:00 395264 bytes
joy.cpl: 5.01.2600.1106 German Final Retail 8/29/2002 03:43:42 66560 bytes
gcdef.dll: 5.01.2600.0000 German Final Retail 8/23/2001 14:00:00 78336 bytes
pid.dll: 5.01.2600.1106 English Final Retail 8/29/2002 03:43:28 31744 bytes
gameenum.sys: 5.01.2600.1106 English Final Retail 8/29/2002 01:32:44 9856 bytes
dsound.dll: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 336384 bytes
dsound3d.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 1294336 bytes
dswave.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18432 bytes
dsdmo.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 186880 bytes
dsdmoprp.dll: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 70656 bytes
dmusic.dll: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 97280 bytes
dmband.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 27136 bytes
dmcompos.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 58368 bytes
dmime.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 171520 bytes
dmloader.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 33280 bytes
dmstyle.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 98816 bytes
dmsynth.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 100864 bytes
dmscript.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 76800 bytes
system.dll: 1.00.3705.0288 English Final Retail 8/28/2002 17:02:39 1167360 bytes
system.dll: 1.01.4322.0573 English Final Retail 6/26/2003 01:32:21 1216512 bytes
Microsoft.DirectX.Direct3D.dll: 5.03.0000.0900 English Final Retail 7/6/2003 02:01:49 274432 bytes
Microsoft.DirectX.Direct3DX.dll: 5.03.0000.0900 English Final Retail 7/6/2003 02:01:49 1701376 bytes
Microsoft.DirectX.DirectDraw.dll: 5.03.0000.0900 English Final Retail 7/6/2003 02:01:49 133120 bytes
Microsoft.DirectX.DirectInput.dll: 5.03.0000.0900 English Final Retail 7/6/2003 02:01:49 141824 bytes
Microsoft.DirectX.DirectPlay.dll: 5.03.0000.0900 English Final Retail 7/6/2003 02:01:50 237056 bytes
Microsoft.DirectX.DirectSound.dll: 5.03.0000.0900 English Final Retail 7/6/2003 02:01:50 138752 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.03.0000.0900 English Final Retail 7/6/2003 02:01:49 43520 bytes
Microsoft.DirectX.Diagnostics.dll: 5.03.0000.0900 English Final Retail 7/6/2003 02:01:49 13824 bytes
Microsoft.DirectX.dll: 5.03.0000.0900 English Final Retail 7/6/2003 02:01:50 203264 bytes
dx7vb.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 602624 bytes
dx8vb.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 1189888 bytes
dxdiagn.dll: 5.03.0001.0902 German Final Retail 5/30/2003 09:00:02 1048576 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/23/2001 14:00:00 924432 bytes
mfc42.dll: 6.00.8665.0000 English Beta Retail 8/23/2001 14:00:00 995383 bytes
wsock32.dll: 5.01.2600.0000 German Final Retail 8/23/2001 14:00:00 23552 bytes
amstream.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 64512 bytes
devenum.dll: 6.05.0001.0902 German Final Retail 5/30/2003 09:00:02 53248 bytes
dxmasf.dll: 6.04.0009.1125 German Final Retail 8/29/2002 03:43:20 499741 bytes
mciqtz.drv: 4.00.0096.0729 English Final Retail 8/17/1998 11:21:54 11776 bytes
mciqtz32.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 34304 bytes
mpg2splt.ax: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 136192 bytes
msdmo.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 13312 bytes
encapi.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18944 bytes
qasf.dll: 9.00.0000.2980 English Final Retail 12/11/2002 17:34:40 241664 bytes
qcap.dll: 6.05.0001.0900 German Final Retail 12/12/2002 00:14:32 177152 bytes
qdv.dll: 6.05.0001.0900 German Final Retail 12/12/2002 00:14:32 268800 bytes
qdvd.dll: 6.05.0001.0902 German Final Retail 5/30/2003 09:00:02 356352 bytes
qedit.dll: 6.05.0001.0900 German Final Retail 12/12/2002 00:14:32 525824 bytes
qedwipes.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 733184 bytes
quartz.dll: 6.05.0001.0902 German Final Retail 5/30/2003 09:00:02 1251840 bytes
quartz.vxd: Final Retail 8/17/1998 11:21:56 5672 bytes
strmdll.dll: 4.01.0000.3928 German Final Retail 8/29/2002 03:43:32 251904 bytes
vidx16.dll: 0.00.0000.0000 English Final Retail 8/17/1998 11:21:56 10240 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/23/2001 14:00:00 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/23/2001 14:00:00 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/23/2001 14:00:00 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/23/2001 14:00:00 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/23/2001 14:00:00 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/23/2001 14:00:00 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/23/2001 14:00:00 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/23/2001 14:00:00 154624 bytes
mswebdvd.dll: 6.05.0001.0900 German Final Retail 12/12/2002 00:14:32 196096 bytes
ks.sys: 5.03.0000.0900 German Final Retail 12/12/2002 01:14:32 130304 bytes
ksproxy.ax: 5.03.0000.0900 German Final Retail 12/12/2002 01:14:32 117248 bytes
ksuser.dll: 5.03.0000.0900 German Final Retail 12/12/2002 01:14:32 4096 bytes
stream.sys: 5.03.2600.1164 German Final Retail 1/30/2003 17:55:44 45056 bytes
mspclock.sys: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 5248 bytes
mspqm.sys: 5.01.2600.0000 German Final Retail 8/23/2001 14:00:00 4608 bytes
mskssrv.sys: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 7424 bytes
swenum.sys: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 4096 bytes
mstee.sys: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 5504 bytes
bdaplgin.ax: 5.03.0000.0900 German Final Retail 2/17/2003 10:16:26 16896 bytes
bdasup.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:26 11392 bytes
msdvbnp.ax: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:26 52224 bytes
psisdecd.dll: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:28 354816 bytes
psisrndr.ax: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:28 30208 bytes
ipsink.ax: 5.03.0000.0900 German Final Retail 2/17/2003 10:16:26 14848 bytes
mpeg2data.ax: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:26 57856 bytes
ndisip.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 10112 bytes
mpe.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:26 15104 bytes
streamip.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 14976 bytes
msvidctl.dll: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:28 1230336 bytes
slip.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 10880 bytes
nabtsfec.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 83968 bytes
ccdecode.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:26 16384 bytes
vbisurf.ax: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:30 27648 bytes
msyuv.dll: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 16896 bytes
kstvtune.ax: 5.03.0001.0902 German Final Retail 6/4/2003 10:30:32 274432 bytes
ksxbar.ax: 5.03.0001.0902 English Final Retail 6/4/2003 09:18:28 39424 bytes
kswdmcap.ax: 5.03.0000.0900 German Final Retail 2/17/2003 10:16:32 226304 bytes
vfwwdm32.dll: 5.01.2600.1106 German Final Retail 8/29/2002 03:43:32 50176 bytes
wstcodec.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:32 18688 bytes
wstdecod.dll: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:32 47104 bytes
msdv.sys: 5.01.2600.0000 English Final Retail 2/17/2003 10:21:50 52096 bytes
DirectShow Filters
WDM Streaming-VBI-Codecs:
NABTS/FEC VBI-Codec,0x00200000,2,1,,5.03.0000.0900
Untertiteldecoder,0x00200000,2,1,,5.03.0000.0900
WST-Codec,0x00200000,1,1,,5.03.0000.0900
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
DivX Decoder Filter,0x00800000,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.00.3312.0000
InterVideo Audio Processor Fx,0x00400000,1,1,Auprocfx.ax,
Vorbis Decoder,0x00600000,1,1,OggDS.DLL,0.09.0009.0005
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.0001.0902
ATI MPEG Audio Decoder,0x00200000,1,1,atidvcr.dll,8.05.0000.30506
Creative EAX Dream,0x001fffff,2,0,CTDream.ax,1.00.0005.0000
InterVideo MPEG Audio Encoder,0x00200000,1,1,iviaenc.ax,1.08.0013.0000
Nero Scene Detector 2,0x00200000,2,0,NeSceneDetector.ax,1.00.0000.0007
DV Muxer,0x00400000,0,0,qdv.dll,6.05.0001.0900
DV Scenes,0x00200000,1,1,NVDV.dll,
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.0001.0902
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.2980
Audio Source,0x00200000,0,1,wmprevu.dll,9.00.0000.2980
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.0001.0902
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.0001.0902
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
NVIDIA Audio Decoder,0x00800000,1,1,nvauddec.ax,0.00.0000.0255
NVIDIA Video Decoder,0x00800000,2,3,nvviddec.ax,0.00.0000.0255
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.0001.0900
DScaler Renderer,0x00200000,1,0,DSRend.dll,1.02.0000.0000
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
Xing® VideoCD Navigator,0x00600000,0,2,rpds3260.dll,6.00.0008.0642
StreamBufferSink,0x00200000,0,0,sbe.dll,
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902
DummyMpeg2Source,0x00200000,0,1,GCFilter.ax,2.00.0001.0002
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.00.3312.0000
InterVideo MPEG Video Encoder,0x00200000,1,1,ivivenc.ax,1.08.0013.0000
InterVideo Multiplexer,0x00200000,1,1,ivimux.ax,1.08.0013.0000
Nero Mpeg Audio Encoder,0x00200000,1,1,NeAudioEnc.ax,1.00.0000.0004
PN Wrap filter,0x00400000,0,2,pnwrap.dll",
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.0001.0902
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
CyberLink MPEG Video Encoder,0x00200000,1,1,mpgvenc.ax,1.00.0000.0001
MP3 Encoder Filter,0x00200000,1,0,,
ATI Time Shift Splitter,0x00600000,1,3,atidvcr.dll,8.05.0000.30506
ATI Time Shift Reader,0x00600000,0,1,atidvcr.dll,8.05.0000.30506
ATI Time Shift Writer,0x00200000,1,0,atimpenc.dll,8.05.0000.30506
ATI MPEG Video Decoder,0x00600000,1,1,atidvcr.dll,8.05.0000.30506
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0006
Anvil Source,0x00400000,0,1,AnvilFlt.OCX,1.00.0002.0000
RendFile,0x00200000,1,0,AnvilFlt.OCX,1.00.0002.0000
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.0001.0900
Internal LMRT Renderer,0x00800001,1,0,LMRTREND.dll,6.00.0004.0827
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Record Queue,0x00200000,1,1,wmmfilt.dll,1.02.2541.0001
Deinterlace Filter,0x00200000,1,1,hcwdlace.ax,1.01.0000.0000
WMS Filter,0x00400000,0,1,CTWMSFLT.dll,1.12.0001.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.0001.0902
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.0001.0902
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.2980
CyberLink MPEG Muxer,0x00200000,2,1,mpgmux.ax,2.00.0000.0001
Nero Format Converter,0x00200000,1,1,NeroFormatConv.ax,1.00.0000.0042
ATI Video Format Converter,0x00200000,1,1,atidvcr.dll,8.05.0000.30506
TrueMotion 2.0 Decompressor,0x00600001,1,1,tm20dec.ax,1.00.0000.0001
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.00.3312.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.0001.0900
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.0001.0902
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
ATI Line21 CC Decoder/Renderer,0x00200000,1,0,ATICCap.ax,8.05.0000.0001
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
Disk Record Queue,0x00200000,1,1,wmedque.dll,9.00.0000.2980
Noise Reduction,0x00100000,1,1,DSNOISER.AX,1.00.0000.0001
DV Source Filter,0x00400000,0,1,NVDV.dll,
Color Converter,0x00200000,1,1,declrds.ax,9.00.0000.2980
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.2980
NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ATI MPEG Audio Encoder,0x00200000,1,1,atimpenc.dll,8.05.0000.30506
NetShow Theater Source Filter,0x00600000,0,2,qnspro.dll",
Position,0x00200000,1,1,GCFilter.ax,2.00.0001.0002
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.0001.0902
Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.2980
Video Renderer,0x00800001,1,0,quartz.dll,6.05.0001.0902
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.0001.0902
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.0001.0902
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.0000.0900
Video Renderer,0x00400000,1,0,quartz.dll,6.05.0001.0902
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mp4sds32.ax,8.00.0000.0344
ATI MPEG Video Encoder,0x00200000,1,1,atimpenc.dll,8.05.0000.30506
Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0006
Nero Vcd Navigator,0x00600000,0,2,NeVcd.ax,1.02.0000.0004
Nero Audio Format Converter,0x00200000,1,1,NeAudioConv.ax,1.00.0000.0002
ATI MPEG Multiplexer,0x00200000,3,1,atimpenc.dll,8.05.0000.30506
Vorbis Stream Encoder,0x00600000,1,1,MediaXW.dll,0.00.0006.0000
ATI Audio Delay Filter,0x00200000,1,1,atidvcr.dll,8.05.0000.30506
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.2980
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.0000.0900
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0006
File writer,0x00200000,1,0,qcap.dll,6.05.0001.0900
VIVO Audio Decoder Filter,0x00800002,1,1,vvaudflt.ax,3.00.0000.0000
Vorbis Encoder,0x00200000,1,1,OggDS.DLL,0.09.0009.0005
ASUS MUX,0x00200000,2,0,asus_mux.ax,8.00.0000.0000
Ogg Multiplexer,0x00400000,1,1,OggDS.DLL,0.09.0009.0005
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.00.3312.0000
ATI MPEG Archiver,0x00200000,0,0,atidvcr.dll,8.05.0000.30506
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.0001.0902
Cyberlink Dump Filter,0x00200000,1,0,cldump.ax,1.00.0000.0000
Hauppauge WinTV SnapShot,0x00200000,1,1,hcwsnap.ax,1.12.21077.0000
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.0001.0902
CyberLink MPEG-1 Audio Encoder,0x00200000,1,1,m1aenc.ax,1.00.0000.0000
Cutlist File Source,0x00200000,0,1,qcut.dll,6.00.0002.0902
AVI Draw,0x00600064,9,1,quartz.dll,6.05.0001.0902
.RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.2980
Nero File Source / Splitter,0x00600000,0,3,NeFSource.ax,1.00.0000.0001
ATI Still Capture Filter,0x00200000,1,0,atimpenc.dll,8.05.0000.30506
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.0001.0900
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.0001.0900
Creative MP3 Source Filter,0x00400000,0,1,CTMp3SFt.dll,1.00.0010.0000
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.2980
ClearVideo® Decompression Filter,0x00800000,1,1,clramd.ax,2.00.0000.0001
AC3 Source Filter,0x00400000,0,1,AC3Filt.dll,1.12.0000.0000
Screen Capture filter,0x00200000,0,1,wmesrcwp.dll,9.00.0000.2980
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
VIVO Video Decoder Filter,0x00600001,1,1,vvvidflt.ax,3.00.0000.0000
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
ATI Noise Reduction Filter,0x00200000,1,1,atidvcr.dll,8.05.0000.30506
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Nero Video Processor,0x00200000,1,1,NeroVideoProc.ax,1.00.0000.0046
URL StreamRenderer,0x00600000,1,0,LMRTREND.dll,6.00.0004.0827
Lava Filter,0x00200000,1,1,,
Nero Video Decoder,0x00600000,2,1,NeVideo.ax,1.01.0007.0006
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.0001.0900
Null Renderer,0x00200000,1,0,qedit.dll,6.05.0001.0900
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.00.3312.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,6.05.0001.0900
IVF source filter,0x00600000,0,1,ivfsrc.ax,5.10.0002.0051
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,
ATI Audio Pitch Correction Filter,0x00200000,1,1,atidvcr.dll,8.05.0000.30506
Smart Tee,0x00200000,1,2,qcap.dll,6.05.0001.0900
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.0001.0902
Nero Scene Detector,0x00200000,1,0,NeSceneDetector.ax,1.00.0000.0007
NVIDIA Navigator,0x00600000,0,3,nvnav.ax,0.00.0000.0255
RealPlayer Audio Filter,0x00200000,1,1,rpds3260.dll,6.00.0008.0642
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
InterVideo Audio Effects,0x00200000,1,1,iviaudioeff.ax,3.01.0091.0142
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.0001.0902
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.0001.0902
Wave Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
File stream renderer,0x00400000,1,1,quartz.dll,6.05.0001.0902
XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.2980
Nero File Source,0x00200000,0,1,NeFileSrc.ax,1.00.0000.0005
NVF Filter,0x00400000,0,1,CTNvfFlt.dll,1.00.0000.0000
InterVideo Still Capture,0x00200000,1,1,iviscapt.ax,1.08.0013.0000
Video Source,0x00200000,0,1,wmprevu.dll,9.00.0000.2980
Nero DVD Decoder,0x00600000,2,1,NeVideo.ax,1.01.0007.0006
NeroDigital Parser,0x00600000,0,3,NDParser.ax,1.00.0001.0028
AVI Mux,0x00200000,1,0,qcap.dll,6.05.0001.0900
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.0001.0902
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.0001.0902
File Source (URL),0x00400000,0,1,quartz.dll,6.05.0001.0902
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
PVTimeScale Plugin,0x00200000,1,1,Amsdspvt.dll,1.00.0000.0001
Nero Frame Capture,0x00200000,1,1,NeCapture.ax,1.04.0000.0003
InterVideo Down Scale Filter,0x00200000,1,1,ividownscale.ax,1.08.0013.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
Ogg Splitter,0x00600000,1,1,OggDS.DLL,0.09.0009.0005
Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0006
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
NVVPE,0x00600000,1,1,FILTER.AX,1.00.0000.0001
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.02.2541.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.0001.0900
ASUS ASV2 Video CODEC,0x00200000,1,1,asusasv2.ax,1.00.0000.0000
InterVideo File Writer,0x00200000,1,0,iviwriter.ax,1.08.0013.0000
BDA MPEG2 Transport Information Filter,0x00200000,1,0,psisrndr.ax,6.05.0001.0900
Allocator Fix,0x00200000,1,1,wmmfilt.dll,1.02.2541.0001
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.02.2541.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.0001.0902
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Voxware MetaVoice Audio Decoder,0x00999998,1,1,voxmvdec.ax,1.00.0000.0011
Voxware MetaSound Audio Decoder,0x00999999,1,1,voxmsdec.ax,1.00.0000.0011
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming-Tee/Splitter-Geräte:
Tee/Sink-to-Sink-Konvertierung,0x00200000,1,1,,5.03.0000.0900
WDM Streaming-Daten-Transforms:
Microsoft Kernel-Echounterdrückung,0x00200000,2,2,,5.03.0000.0900
Microsoft Kernel GS Wavetablesynthesizer,0x00200000,1,1,,5.03.0000.0900
Microsoft Kernel-DLS-Synthesizer,0x00200000,1,1,,5.03.0000.0900
Microsoft Kernel-DRM-Audioentschlüsselung,0x00200000,1,1,,5.03.0000.0900
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.0001.0900
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
Indeo® Video 5.11 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.0001.0902
Nero Video Encoder,0x00200000,1,1,,
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.0001.0900
DivX 5.0.2 Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.0001.0900
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel IYUV Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft MPEG-4 Video Codec V2,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft MPEG-4 Video Codec V1,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.0001.0900
VDOnet VDOWave,0x00200000,1,1,qcap.dll,6.05.0001.0900
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
Nero Audio Encoder,0x00200000,1,1,NeAudioEnc.ax,1.00.0000.0004
IAC2,0x00200000,1,1,quartz.dll,6.05.0001.0902
Lernout & Hauspie CELP 4.8kbit/s,0x00200000,1,1,quartz.dll,6.05.0001.0902
Lernout & Hauspie SBC 8kbit/s,0x00200000,1,1,quartz.dll,6.05.0001.0902
Lernout & Hauspie SBC 12kbit/s,0x00200000,1,1,quartz.dll,6.05.0001.0902
Lernout & Hauspie SBC 16kbit/s,0x00200000,1,1,quartz.dll,6.05.0001.0902
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.0001.0902
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.0001.0902
ACELP.net,0x00200000,1,1,quartz.dll,6.05.0001.0902
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.0001.0902
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.0001.0902
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.0001.0902
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.0001.0902
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.0001.0902
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.0001.0902
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.0001.0902
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.0001.0902
Audio Capture Sources:
SB Live! Audio [9400],0x00200000,0,0,qcap.dll,6.05.0001.0900
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.0001.0902
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.0001.0902
SB Live! MIDI-Anschluss [9400],0x00200000,1,0,quartz.dll,6.05.0001.0902
SB Live! Sw-Synth [9400],0x00200000,1,0,quartz.dll,6.05.0001.0902
SB Live! Synth A [9400],0x00200000,1,0,quartz.dll,6.05.0001.0902
SB Live! Synth B [9400],0x00200000,1,0,quartz.dll,6.05.0001.0902
WDM Streaming-Capturegeräte:
Hauppauge WinTV Capture,0x00200000,1,3,,5.03.0000.0900
SB Live! MIDI-Anschluss [9400],0x00200000,2,2,,5.03.0000.0900
SB Live! Audio [9400],0x00200000,3,2,,5.03.0000.0900
WDM Streaming-Wiedergabegeräte:
SB Live! DirectMusic Synthesizer [9400],0x00200000,1,1,,5.03.0000.0900
SB Live! Sw-Synth [9400],0x00200000,1,1,,5.03.0000.0900
SB Live! Synth A [9400],0x00200000,1,1,,5.03.0000.0900
SB Live! Synth B [9400],0x00200000,1,1,,5.03.0000.0900
BDA-Wiedergabefilter:
BDA-IP-Sink,0x00200000,1,1,,5.03.0000.0900
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBS Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBT Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Video Capture Sources:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,psisrndr.ax,6.05.0001.0900
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,6.05.0001.0900
WDM Streaming-TV-Empfangsgeräte:
Hauppauge WinTV TvTuner,0x00200000,0,3,,5.03.0001.0902
WDM Streaming-Crossbar-Geräte:
Hauppauge WinTV Crossbar,0x00200000,7,2,,5.03.0001.0902
WDM Streaming-TV-Audiogeräte:
Hauppauge WinTV TvAudio,0x00200000,1,1,,5.03.0001.0902
WDM Streaming-Mixer:
Microsoft Kernel-Waveaudiomixer,0x00200000,2,2,,5.03.0000.0900
BDA CP/CA Filters:
Decrypt/Tag,0x00200000,0,0,encdec.dll,
Encrypt/Tag,0x00200000,0,0,encdec.dll,
XDS Codec,0x00200000,0,0,encdec.dll,
WDM Streaming-Kommunikations-Transforms:
Audio Renderers:
SB Live! Audio [9400],0x00200000,1,0,quartz.dll,6.05.0001.0902
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.0001.0902
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.0001.0902
DirectSound: SB Live! Audio [9400],0x00200000,1,0,quartz.dll,6.05.0001.0902
WDM Streaming-Systemgeräte:
SB Live! DirectMusic Synthesizer [9400],0x00200000,11,2,,5.03.0000.0900
SB Live! Synth A [9400],0x00200000,3,2,,5.03.0000.0900
SB Live! Synth B [9400],0x00200000,13,2,,5.03.0000.0900
SB Live! MIDI-Anschluss [9400],0x00200000,13,2,,5.03.0000.0900
SB Live! Audio [9400],0x00200000,12,2,,5.03.0000.0900
BDA-Empfängerkomponente:
BDA Slip De-Framer,0x00600000,1,1,,5.03.0000.0900
Reply 1 of 12, by eL_PuSHeR
Ouch! You should keep your machine specs a little smaller, fellow.
Anyway, have you tried booting into VGA mode? Use F8 at startup. This way it could help to isolate the problem.
Reply 2 of 12, by Nicht Sehr Gut
Originally posted by Unregistered First of all, VDMSound is a great program! I noticed, however, some quirks on my machine when running certain VESA DOS games using VDMSound Launchpad.
Actually, this probably isn't related to VDMSound.
Odds are, this is entirely your video card and it's drivers. XP doesn't normally allow direct hardware access, Full-screen DOS video is the exception to that rule.
Some ideas?
Not many. You can try testing your VESA compatibility as described in this thread.
System Information
Holy cow! If you're not going to edit down your system stats, please paste them as a text file attachment to your post.
Reply 4 of 12, by Unregistered
Hi there,
thanks for your kind responses. Sorry, I was quite in a hurry making the post - I should take the time to register not to leave such a mess with sys specs.
New findings:
- VDMSound 2.1.0 doesn't change situation
- nolfb doesn't help
- booting into VGA mode --> no garbling after exit!
to DosFreak:
1. Only Radeon 9700's or 9500 Pro's as well? In fact, mine is a 9500 Pro - just changed the BIOS device id to circumvent overclocking locks
2. Which tool/command to reset the screen are you speaking of? That would be helpful!
BTW, as I have the possibility, let me thank you for the tips I read on the NTCompatible message boards regarding the Compatibility Toolkit and its hidden fixes (already some time ago, Windows 2000 era; I didn't post there but read the threads and found them helpful)
Best regards
Reply 5 of 12, by Snover
Wait...
you're overclocking, and then complaining about a garbled screen?
Yes, it’s my fault.
Reply 6 of 12, by Unregistered
Snover wrote:
Wait...
Sorry for the misunderstanding!
To make it clear:
- My system is NOT overclocked (neither CPU nor GPU; RAM is at 355 MHz but that's ok since it is DDR400 RAM)
- Changing the device ID of the Sapphire 9500 Pro was only a "proactive" measure in case I wanted to overclock; but I haven't so far. Only tried it once or twice using 3DMark2003. I also wanted to avoid confusing XP's hardware detection/product activation.
- the ID change hasn't had any negative influence so far, graphics card is running for about half a year now
- I want to point out that this garbling problem is ONLY related to VESA DOS apps
- Windows, DirectX and OpenGL apps run like a charm - there are no overclocking artifacts as you supposed; you should have seen me playing Tron 2.0 yesterday, there was nothing negative to notice
Hope I could clear that up.
Reply 7 of 12, by Unregistered
I have the same problem with Ati Radeon 9100 and XP. Unfortunately, it seems that the reason is XP + newer Catalyst drivers. You can find some discussion on the issue in Rage3d forums, for example http://www.rage3d.com/board/showthread.php?th … &highlight=vesa .
You are not alone. Only fix I have found out is to change desktop resolution and then to change it back to get rid of the corruption.
Reply 8 of 12, by silverfoxx
first of all id like to say that this problem is common with the 9600 too.
And second of all. Is it bad if you overclock your system? I got a utlity installed (game gain) wich automaticly overclocks your pc for games..
How do i get pandora to work propperly?!
Reply 10 of 12, by Guest
Hi guys!
Sorry, work's eating up my time.
Good news - give the 3.7 catalyst drivers a try, I installed them yesterday and today I tried Mission Critical - no VESA probs any longer! I also tried a DOS vgatest.exe with VESA modes (no VDMSound involved) - also no garbling.
Thanks to all who had valuable input. Sorry for mistakingly choosing the wrong forum.
Greets, the original poster
Reply 11 of 12, by Guest
Ahh, and by the way - I just found out that some dumbass registered the username "Unregistered" - I was just glad that the username "Guest" also works for anonymous posting, otherwise I would not have been able to let you know about my new findings.
Greetings
Reply 12 of 12, by Snover
should not be possible to register that username...🤣...methinks it's time to fix that
Yes, it’s my fault.
