First post, by Unregistered
Got Stonekeep all installed and got the sound working in the installation program, but when I run the game it says I'm out of memory. I've set EMS and XMS to max, but no go. Any suggestions?
This has been solved, please use Quick Search.
showthread.php?s=&threadid=206&highlight=stonekeep
Specifically, patch to 1.2, then edit the Stonekeep PIF shortcut and add the argument OTHER_OS to the command line (remove the WIN95 argument).
Yes, it’s my fault.
OK, I tried what was listed in the other post:
This one bugged me for ages - but I refused to give up.
Here is the solution.
First up make sure you have the latest versions of both VDMS and Stonekeep (patch 1.2).
Second, run setup by right clicking on the setup.exe and pick run with VDMS.
Then edit your SK.bat file and add the line "dosdrv" before the game executable.
Finally edit the Stonekeep PIF shortcut and add the argument OTHER_OS to the command line (remove the WIN95 argument).
But this didn't work for me. Only difference I can see is that I'm running WP instead of Win 2k. Any other suggestions?
I'm pretty sure it works under WinXP because I have been playing it recently. You must have done something wrong in the process.
BTW: This game is quite bad for an RPG imho. Go get something else...
