First post, by Cadavre777
Greetings
I have been having trying to build Dosbox (h-a-l-9000's megabuild 4.1) on NetBSD 4.0.1(stable i386) and I have run out of luck. Plain Dosbox 0.72 builds just fine, so there shouldn't any dependencies that have not been met.
Let me show where the problem is...
Making all in visualcg++ -g -O2 -I/usr/X11R6/include/freetype2 -I/usr/X11R6/include -o dosbox dosbox.o cpu/libcpu.a debug/libdebug.a dos/libdos.a fpu/libfpu.a hardware/libhardware.a gui/libgui.a ints/libints.a misc/libmisc.a shell/libshell.a hardware/serialport/libserial.a hardware/parport/libparallel.a libs/gui_tk/libgui_tk.a libs/porttalk/libporttalk.a -lSDL_sound -lm -L/usr/pkg/lib -Wl,-rpath,/usr/pkg/lib -lSDL -lpthread -L/usr/X11R6/lib -lfreetype -lz -lpcap -lSDL_nethardware/libhardware.a(sblaster.o): In function `SBLASTER_ShutDown(Section*)':/home/test/dosbox/src/hardware/sblaster.cpp:1568: undefined reference to `HWOPL_Cleanup()'hardware/libhardware.a(sblaster.o): In function `SBLASTER':/home/test/dosbox/src/hardware/sblaster.cpp:1494: undefined reference to `HARDOPL_Init(unsigned int, unsigned int)'ints/libints.a(bios.o): In function `BIOS_HostTimeSync':/home/test/dosbox/src/ints/bios.cpp:338: undefined reference to `ftime'*** Error code 1
This is the process I followed after unpacking the megabuild and changing directory.
$ sh autogen.sh && ./configure
make
Unfortunately I require the lpt support in megabuild 4.1 for the application I intend to use (even though dosbox was intended for games) as there are no commercial systems available which meet the requirements.
As far as I can see, ftime is the culprit in bios.cpp. Is there something I'm not doing correctly or just not doing? Please note I'm not a developer, changing any code myself would just make more problems.
Any ideas? Mods, please move this thread if I have put it in the wrong section.
Thanks
Cadavre777
