First post, by rixasha
I was thinking of purchasing Wolfenstein 3D and Spear of Destiny from the id software web store, but my question on whether the versions on sale are the original DOS versions went unanswered. Has anyone here purchased these titles, and what do the downloads contain?
I would be playing them on real DOS and DOSBox, and it wouldn't be the first time that something having DOS in its system requirements turns out in fact to be just a Windows port.
Reply 1 of 36, by eL_PuSHeR
[MOVED]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 36, by leileilol
They have no official Windows versions, and their official code only compiles for dos, so yes, they would be the DOS versions. On Steam, it's bundled with a protected version of DOSBox.
long live PCem
Debian's fucked
Reply 3 of 36, by MiniMax
Rank Moderator
Moderator
Bundled, not tied. Means you can run the games using whatever DOSBox version you want.
_________________
Reply 4 of 36, by Qbix
Rank DOSBox Author
DOSBox Author
And the version of DOSBox isn't protected (anymore)
Water flows down the stream
Reply 5 of 36, by static-
how was it "protected" ?
Reply 6 of 36, by wd
Rank DOSBox Author
DOSBox Author
exe wrapper that checks for steam presence
Reply 7 of 36, by Dr. Riptide
That wrapper code seems to have been done away with for everything on Steam that uses DOSBox, meaning the Steam versions of those two games are indeed original DOS versions and have no copy protection whatsoever.
Intel Q6600 (2.4 GHz) | 4GB RAM | GeForce 8800 GT | Windows 7 64-bit
Reply 8 of 36, by Calvero
Didn't the original Spear of Destiny have copy protection by asking you for a question and you having to look up the answer in the manual? (or typing a special word that bypassed this copy protection)
Reply 9 of 36, by Dr. Riptide
I don't know, but if so that's been done away with also.
Reply 10 of 36, by static-
neat. something requested by dosbox team or they just took self-initiative?
Reply 12 of 36, by static-
ya me neither.
Reply 13 of 36, by leileilol
DosFreak wrote:
I don't remember there ever being copy protection for Spear of Destiny.
There is, it just asks you general trivia questions about the game's manual and id software
long live PCem
Debian's fucked
Reply 15 of 36, by prozoam
Yeah, my old Spear of Destiny retail CD had the manual check questions too. I played that so much I, to this day, still have all the answers memorized.
Reply 16 of 36, by franpa
It broke the DOSBbox license iirc which is what forced Steam to re-release the games with an unprotected version of DOSbox.
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 17 of 36, by wd
Rank DOSBox Author
DOSBox Author
Nope it wasn't forced from our side, they used the stock 0.72 release and
added a wrapper which pretty likely complies with the license (who knows).
Reply 18 of 36, by rixasha
Thanks for all the info. I purchased Wolf3d from the id software web store and got what I wanted. I'll probably get Spear of Destiny too, once I'm done with this.
Reply 19 of 36, by danielc
Highly recommended:
http://www.doomworld.com/wolfendoom/
I have ported the Wolfenstein missions to DOOM II, creating what is essentially an improved and updated Wolfenstein. Each scenario is painstakingly recreated as a DOOM II WAD, complete with all the Wolfenstein textures, objects, sounds, and enemies. The result is a total conversion, a complete Wolfenstein experience which takes full advantage of the DOOM engine. There are even ambient sounds.
In addition to recreating the original missions, I have also created brand new scenarios which go beyond the original scope and concept of Wolfenstein. Scenarios such as Operation: Arctic Wolf, Operation: Rheingold, and the Astrostein Trilogy take the Wolfenstein fan where no Wolfenstein has gone before, immersing the player in adventures not possible with the original Wolfenstein.
It's a total conversion for Doom (also compatible with some Windows sourceports of the Doom engine, with optional mouselook and hi-res and all that) that has the original Wolf3D, SoD, and around 10 more expanded-universe episodes (from memory).
I played the whole series a few years ago, and have replayed them so many times - they are GOLD and highly recommended (although you need a registered version of DOOM2 aswell, specifically the IWAD).
Regards,
CosmicDan
