First post, by inkcoder
Hello everyone, I'm new to DOSBox and I'm having some trouble starting up the elder scrolls : arena.
I downloaded the The Elder Scrolls : Arena from http://elderscrolls.com, and it directed me that if I wanted to run the game I would need a DOS Emulator, they suggested DOSBox. I downloaded DOSBox 0.72, and ran it. I put the Elder Scrolls files into folder: C:\ARENA and read the instructions for what I needed to do run it via DOSBox...
It tells me first to type this in so I can mount the C drive...
MOUNT C C:\ARENA
then to get into our now mounted C drive...
C:
Now here is where I run into some trouble, it tells me to set the directory to C:\ARENA so I can run the game...
CD C:\ARENA
When I run this command it tells me: UNABLE TO CHANGE TO C:\ARENA
The ARENA file is right there in C:\ARENA and I'm not sure what to do. I don't know if it matters but I'm using Windows Vista...
Help would be great,
Inkcoder
