DOSBox Autoexec PROBLEM!!!!
First post, by casobs2
😕 I was wanting to have dosbox get into Master of Orion 2 almost automatically, however, Im running into problems, and I dont know how to get out.
I used the dosbox config editor to edit the dosbox.conf, now it is being weird, it told it to:
mount c C:\MPS
mount e E:\ -t cdrom
c:
however, after the c:, it types joysticktype=2axis automatically, I didnt tell this and now the game runs Superman's OPPOSITE slow.
I tried to fix this, however it tells me when I use the editor to fix the file:
File not correct
section items not 14
program exits...
I was like ok, open the dosbox.conf file using notepad, and it doesnt say any changes under autoexec
this was weird to me so I tried uninstalling the program and reinstall, however it does the same thing, tried uninstalling, deleting everything dosbox, then reinstalling, still the same thing happens. Does anyone have any ideas on how to get rid of the commands, Id rather type everything manually and have the game running tiptop, then having the game execute automatically and running like a**! 😕
Reply 1 of 29, by MiniMax
Rank Moderator
Moderator
Open the status window and check EXACTLY which configuration DOSBox is using.
_________________
Reply 2 of 29, by casobs2
CONFIG:Loading primary settings from config file C:\Program Files (x86)\DOSBox-0.72\dosbox.conf
MIDI:Opened device:win32
Plus, I cannot save the conf with the notepad program
Reply 3 of 29, by casobs2
here is another view of the problem...
Reply 4 of 29, by wd
Rank DOSBox Author
DOSBox Author
So you're on vista, and don't have permissions to edit that file.
Ask your administrator to edit the privilege settings or use other
means to point dosbox to a different config file.
Reply 5 of 29, by casobs2
another view
Reply 6 of 29, by casobs2
I am the administrator of my conputer, there is no other acount on my comp
Reply 7 of 29, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Start DOSBox directly and not through a frontend...
1+1=10
Reply 8 of 29, by casobs2
do you mean with no console?
Reply 9 of 29, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Start->programs->dosbox->dosbox
1+1=10
Reply 10 of 29, by casobs2
k there, still the same thing happens, nothing new
Reply 11 of 29, by wd
Rank DOSBox Author
DOSBox Author
And you can't save files? Wow.
Reply 12 of 29, by casobs2
Look at the the picture and see, that is what happens with this file!
Do not mock me, please!
Reply 13 of 29, by wd
Rank DOSBox Author
DOSBox Author
Well call the microsoft tech support if you can't save a file.
Reply 14 of 29, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Close DOSBox and this D-box thing.
1+1=10
Reply 15 of 29, by casobs2
ok, Ive closed everything, I found a way to save the CONF using notepad, but the same thing still happens, its like its loading from another conf file, but it says it isnt
Reply 16 of 29, by Qbix
Rank DOSBox Author
DOSBox Author
okay.
Uninstall dosbox.
Try installing it in a different location.
for example on c:\users\yourusername\
Water flows down the stream
Reply 17 of 29, by casobs2
okay. Uninstall dosbox. Try installing it in a different location. for example on c:\users\yourusername\ […]
okay.
Uninstall dosbox.
IT GOT RID OF IT THANK YOU, you are a genius!!!!!
Reply 18 of 29, by wd
Rank DOSBox Author
DOSBox Author
CONGRATULATIONS, you are almost a genius!
Reply 19 of 29, by casobs2
thanks for the congrats, but again, please do not mock, you wouldn't like it if I did it to you, patronization is a very demeaning activity, and I do not believe that you that bad, on the inside, so lets just drop the condescension, eh?
Come with me if you want to live...
