First post, by retro games 100
Received a 486-VIP-I02 mobo in bad condition.
This webpage shows the layout -
http://stason.org/TULARC/pc/motherboards/F/FI … 86-VIP-IO2.html
Looking at the above layout, on the right hand side, is a large chip marked KBD. On the mobo itself, this chip is missing. Is it worth my while testing this mobo? (It'll probably take me 30 mins to double-check every jumper, of which there are many on this board, plus time to plug everything in, etc.)
Thanks for any comments. 😀
Reply 1 of 9, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Yep, it's in bad condition as it has a VIA chipset.
If there is not even a socket for the keyboard controller it might be built into the chipset.
1+1=10
Reply 2 of 9, by retro games 100
Please note - when it comes to testing 486 mobos, as they are now getting increasingly rare, I am not bothered if they have "poor" chipsets, such as VIA. I am happy to test any 486s.
Regarding the missing KBD chip, the chip is missing from an area on the mobo which is clearly a socket where you can pull a chip away from, and conversely, push a chip in to this socket. The fact that the chip clearly seems to be missing seems a bad sign to me. (Not the fact that the main chipset is VIA.)
So, can I conclude that this mobo is not worth testing - please forget about the VIA chipset. Thanks a lot. 😀
Edit: I decided to test it. It didn't POST. I tried about 6 different sticks of RAM, and 2 dx2-66 CPUs. Nothing appeared on the screen.
Reply 3 of 9, by Amigaz
My FIC PIO2 mobo also has an empty keyboard socket but the circuitry is integrated in another chip elsewhere
These VIA socket 3 mobo's are pretty good even though they have VIA chipset....so don't count them out yet 😉
Reply 4 of 9, by retro games 100
I'm beginning to think that the missing KBD chip is OK!
But there is something else I really need to understand - and that's RAM configuration. ATM, I just stick in any RAM sticks I have available. I don't know what they are, or what I'm doing.
If you look at the mobo layout specification here -
http://stason.org/TULARC/pc/motherboard...P-IO2.html
It says stuff like this -
17MB - NONE | (1) 256K x 36 | (1) 4M x 36 | NONE
What does 4M x 36 mean for instance? Do I use RAM with chips on one side, or both? What is FP RAM? What am I doing? Why am I here?
Reply 5 of 9, by GL1zdA
256K x 36 means:
36 - memory width - 32 bits + 4 bits for parity.
256k * 32 bits = 256 k * 4 bytes = 1 MByte 72-pin SIMM (72-pin SIMMs have 32-bit memory width or 36-bit with parity chips, 30-pin SIMMs have 8 bit memory width or 9-bit with parity)
4M x 36 means:
4M * 32 bits = 4M * 4 bytes = 16 MByte 72-pin SIMM
FP RAM means FPM SIMMs
getquake.gif | InfoWorld/PC Magazine Indices
Reply 6 of 9, by retro games 100
Thanks for the memory info. I'll have to remember that. 😉
Reply 7 of 9, by Moogle!
Yeah, the missing Keyboard chip is sometimes handled elsewhereo n the board.
Reply 8 of 9, by samudra
VIA had a way better reputation back then than they do now.
They made good stuff.
If you don't want to take my word for it, takes Redhill's.
http://www.redhill.net.au/b/b-95.html
This is not a QEMM error.
Reply 9 of 9, by Moogle!
I still have nightmares about my VIA GRA board. It was an AT mobo that had everything integrated.
