First post, by FragSelf
Hi, I'm having a problem getting the music to work with the original dungeon keeper. Sound works just fine but there's no in game music. The game has the midi music configuration set to none, which seems pretty obvious except when I try to change it, it gives me this error:
XMIDI sound hardware not found
Check driver type and configuration
The only option available is "Creative Labs AWE-32 and AWE-64 <TM> General MIDI" and the only setting I can manually configure is I/O Address, which is set to try 620 H. I have no idea what to do with the i/o setting. I don't have a soundcard but there is audio built into my motherboard: MSI P6N SLI Platinum
Audio Chipset Realtek ALC888
Audio Channels 8 Channels
Running on vista so pretty much limited to dos box.
Any ideas?
