First post, by MiniMax
Rank Moderator
Moderator
The internal HELP command takes precedence over external programs/batch-files.
Re: D-Fend Reloaded (DOSBox frontend)
Is this by design, or an oversight?
_________________
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
well internal commands take precendence over external commands. That is design.
However I don't know if the help in msdos 6.x was an internal or an external command.
So making help an internal command while it might have been an external command can be an oversight.
Water flows down the stream
Reply 2 of 3, by MiniMax
Rank Moderator
Moderator
I don't have real MS-DOS available to test, but in WinXP/cmd a BAT-file named HELP.BAT takes precedence.
_________________
Reply 3 of 3, by Kippesoep
Help was an external command in real DOS. There was a HELP.COM (present on my original DOS 6.22 disk 2).
