First post, by boyofdestiny
- Newbie
I can't post in the guide section, so if someone wants to move it there...
Building dosbox on Ubuntu (whatever architecture) is actually pretty trivial (once it's been done once)
Disclaimer: I've had the dependencies (read as what you need to build dosbox) installed for years, so if I forgot one, let me know.
This whole process can be fully automated with a bash script btw...
So, to make it extra simple, this will make a dosbox folder in your home folder.
Fire up a terminal, (it should start in ~) and just cut n' paste
sudo apt-get install cvs build-essential autoconf automakesudo apt-get build-dep dosboxcvs -z3 -d:pserver:anonymous@dosbox.cvs.sourceforge.net:/cvsroot/dosbox co -P dosboxcd dosbox./autogen.sh./configuremakesudo make install
That's all there is to it.
If you have a dual-core use
make -j3
or quad-core
make -j5
Instead of just make, to compile in parallel.
To update the cvs and rebuild, fire up terminal:
cd dosboxcvs update./autogen.sh./configuremakesudo make install
I followed the steps as I wrote this, so it's something that can be done in a few minutes or less. Have fun with the CVS version!
