Autoexec auto-start?
First post, by spirit
I came across a post that said that, to not have to type in the mount command, at startup, to make a .conf file and add code after
[autoexec]
# Lines in this section will be run at startup.
mount c /d/m
c:
PATH=%PATH%;C:\m
I did so, but still get the z: prompt. I am using Vista 64. What could I be doing wrong?
