First post, by creech42
Anyone had any luck with Discworld. I still can't seem to get sound using VDMSound.
I'm on Windows XP Pro Corp.
I know that Discworld 2 has some issues with sound, but it works. I imagine that they both use the same (or similar) engine, so I'm not sure why Discworld 1 wouldn't.
Yes, it’s my fault.
Well, I don't get this.
I have Win2k PRO @ home and Discworld (as DL'ed from the Underdogs) and everything works just swell (music, speech, etc.). Using VDMSound 2.0.4 with "Update 1" (I imagine it also works without "Update 1"). Using default settings with LaunchPad, so nothing fancy there.
Do you get an error, or just no sound? Have you run CONFIG.BAT/SETSOUND.EXE? Do any other games work with sound on your system?
V.
I finished Discworld2 using VDMSound under WXP. It had some issues with speech like Full Throttle, but it didn't bother me.
I have Discworld1 installed and it starts up fine and music and speech works, but I haven't actually yet played it.
... and I successfully finished Discworkd 1 ( http://www.the-underdogs.org/game.php?name=Discworld ) with VDMSound under Win2k without any problems, with both MIDI music and digitasl sound effects (speech).
Say, creech, check out http://vdmsound.sourceforge.net/compat/list.php?appid=30 -- have you installed the patch?! I think DISC104.EXE is the patch in question. Hmmmm, it appears that the patch is for DWII. Crap. In any case, you can get it from http://www.thediscworld.co.uk/d1patch.htm (link seems broken, try http://www.alltheweb.com/go/1/H/ftp/ftp/ftp.s … s/d/disc_up.zip instead).
If that doesn't work either then tell you what: take a look at the list below and compare it with what you get on your computer. Spot any files that are different and I'll try to send them to you (I did "dir /os" to sort them by size, which should make matching a bit easier).
[size=9]H:\games\discworld>dir /osVolume in drive H has no label.Volume Serial Number is 0CEE-D038Directory of H:\games\discworld25/02/2001 23:51 <DIR> SAVE25/08/2002 12:08 <DIR> ..25/08/2002 12:08 <DIR> .25/02/2001 18:13 16 DISC.BAT20/04/1995 14:54 20 CONFIG.BAT25/02/2001 18:16 36 DWCONF08/03/1995 13:27 256 RM.DRV25/02/2001 23:34 702 MAKECD.BAT08/02/1997 13:59 1'696 NULL.MDI08/02/1997 13:59 2'002 MPU401.MDI08/02/1997 13:58 2'214 PROAUDIO.DIG08/02/1997 13:58 2'871 SBPRO.DIG08/02/1997 13:58 2'923 SB16.DIG08/02/1997 13:58 2'936 RAP10.DIG07/11/1995 06:00 2'971 SNDSCAPE.MDI07/05/1995 13:38 2'980 INDEX08/02/1997 13:58 3'212 SBLASTER.DIG18/01/1995 06:00 3'219 JAMMER.DIG18/01/1995 06:00 3'242 SAMPLE.AD18/01/1995 06:00 3'242 SAMPLE.OPL07/11/1995 06:00 4'171 SNDSCAPE.DIG08/02/1997 13:59 4'792 PCSPKR.MDI08/02/1997 13:59 5'097 TANDY.MDI08/02/1997 13:59 7'018 MT32MPU.MDI18/01/1995 06:00 9'478 ULTRA.DIG18/01/1995 06:00 10'484 SAMPLE.CAT18/01/1995 06:00 10'780 SAMPLE.BNK18/01/1995 06:00 11'278 ADRV688.DIG08/02/1997 13:59 15'073 ADLIB.MDI08/02/1997 13:59 15'205 SBLASTER.MDI08/02/1997 13:59 15'512 PAS.MDI08/02/1997 13:59 15'558 SBPRO1.MDI31/01/1995 06:00 16'073 AILDRVR.LST08/02/1997 13:59 16'464 ADLIBG.MDI08/02/1997 13:59 16'474 OPL3.MDI08/02/1997 13:59 16'545 PASPLUS.MDI08/02/1997 13:59 16'628 SBPRO2.MDI07/05/1995 13:21 26'396 CLAWS1.SCN22/10/1996 19:04 31'396 SBAWE32.MDI07/05/1995 13:15 34'960 PSYGNOSI.SCN18/01/1995 06:00 49'672 ULTRA.MDI07/05/1995 13:21 54'676 CLAWS2.SCN07/05/1995 13:35 57'852 PASTTHIE.SCN07/05/1995 13:21 59'452 CLEAVAGE.SCN07/05/1995 13:21 64'884 DRAGON.SCN07/05/1995 13:15 73'420 TITLE.SCN07/05/1995 13:21 73'540 PASTCITY.SCN07/05/1995 13:19 74'260 CUTANKHM.SCN07/05/1995 13:12 74'612 BOOK.SCN07/05/1995 13:23 75'608 PASTENSU.SCN07/05/1995 13:22 77'996 DONKCART.SCN07/05/1995 13:25 79'368 CUTHIDEO.SCN07/05/1995 13:23 79'728 PASTFISH.SCN
07/05/1995 13:21 85'720 MONK3.SCN07/05/1995 13:23 89'284 ENSUITE.SCN07/05/1995 13:35 90'316 THIEF.SCN07/05/1995 13:22 94'540 DISCMAP.SCN07/05/1995 13:25 101'128 HIDEOUT.SCN07/05/1995 13:26 106'184 INTROHID.SCN07/05/1995 13:15 106'892 CREDITS.SCN07/05/1995 13:21 107'580 DETECTOR.SCN07/05/1995 13:36 110'192 PASTTOIL.SCN07/05/1995 13:29 116'880 MISSILE.SCN07/05/1995 13:30 117'356 PARK.SCN07/05/1995 13:32 118'540 SPACE.SCN07/05/1995 13:29 122'624 CUTPALEN.SCN07/05/1995 13:21 123'880 CELLAR.SCN07/05/1995 13:15 126'440 TWG.SCN07/05/1995 13:21 127'844 CATHOUSE.SCN07/05/1995 13:20 134'304 MONK1.SCN07/05/1995 13:16 134'528 ACT1.SCN07/05/1995 13:16 135'536 ACT2.SCN07/05/1995 13:16 136'388 ACT3.SCN07/05/1995 13:16 136'420 ACT4.SCN07/05/1995 13:30 137'336 REAR.SCN07/05/1995 13:26 138'464 INNROOM.SCN07/05/1995 13:27 139'572 INTROUNI.SCN07/05/1995 13:36 146'768 TOYSHOP.SCN07/05/1995 13:19 150'820 ATUIN.SCN07/05/1995 13:30 151'924 HOLRETRO.SCN07/05/1995 13:29 158'972 MONKCORN.SCN07/05/1995 13:12 162'904 OBJECTS.SCN07/05/1995 13:36 162'932 TOILET.SCN07/05/1995 13:30 166'420 PUB.SCN07/05/1995 13:20 168'032 MONK2.SCN07/05/1995 13:21 168'480 MONK2B.SCN07/05/1995 13:18 169'128 ANKHMAP.SCN07/05/1995 13:21 170'796 MONK5.SCN07/05/1995 13:27 175'280 LIVERY.SCN07/05/1995 13:29 175'692 PASTMONK.SCN07/05/1995 13:25 177'228 PASTINN.SCN07/05/1995 13:16 178'748 CUTALLEY.SCN07/05/1995 13:30 180'284 CUTPUB.SCN07/05/1995 13:30 180'396 RETRO.SCN07/05/1995 13:35 184'948 CUTTEMPL.SCN07/05/1995 13:29 185'944 MIRROR.SCN07/05/1995 13:21 186'316 CLOSET.SCN07/05/1995 13:27 186'564 INTROARC.SCN07/05/1995 13:29 196'008 CUTMONKC.SCN07/05/1995 13:18 199'104 PASTANKH.SCN07/05/1995 13:30 202'636 RECEPTIO.SCN07/05/1995 13:29 203'196 MINEENT.SCN07/05/1995 13:32 209'940 SHEEP.SCN07/05/1995 13:23 213'504 FISHMONG.SCN07/05/1995 13:29 213'644 OVEREDGE.SCN07/05/1995 13:35 215'324 DEATHTHI.SCN07/05/1995 13:30 220'032 HOLRECEP.SCN07/05/1995 13:23 225'196 DEATHFIS.SCN25/02/2001 23:30 225'836 BurnData.rar26/04/1995 11:52 228'878 ENGLISH.TXT07/05/1995 13:24 233'844 FOOL.SCN07/05/1995 13:31 238'380 DEATHROO.SCN07/05/1995 13:20 241'328 CUTBAR.SCN07/05/1995 13:35 242'312 TEMPLE.SCN07/05/1995 13:30 249'452 PAVEMENT.SCN07/05/1995 13:21 261'612 MONK4.SCN07/05/1995 13:20 263'284 BRETHREN.SCN07/05/1995 13:34 266'536 CUTSQUAR.SCN07/05/1995 13:24 268'712 PASTHIDE.SCN07/05/1995 13:20 272'300 BARBER.SCN07/05/1995 13:35 275'144 ROCKROLL.SCN07/05/1995 13:28 282'876 MAMBO.SCN07/05/1995 13:37 282'964 WITCH.SCN07/05/1995 13:21 287'860 CITYGATE.SCN07/05/1995 13:29 288'952 PALENT.SCN07/05/1995 13:21 295'488 PASTCATH.SCN07/05/1995 13:29 297'132 MOUNTPAS.SCN07/05/1995 13:35 300'368 SUNSET.SCN07/05/1995 13:27 301'196 KITCHEN.SCN07/05/1995 13:24 310'448 DEATHFOO.SCN07/05/1995 13:21 312'688 CAMERA.SCN07/05/1995 13:19 314'916 ARCH.SCN07/05/1995 13:18 323'532 ALTAR.SCN23/03/1995 14:35 325'221 SETSOUND.EXE07/05/1995 13:23 330'312 ENDGAME.SCN07/05/1995 13:34 332'308 PASTSTRE.SCN07/05/1995 13:37 344'860 WORLDEDG.SCN07/05/1995 13:30 354'156 RAMKIN.SCN07/05/1995 13:30 354'268 PASTPARK.SCN07/05/1995 13:29 356'672 MYSTWOOD.SCN07/05/1995 13:26 359'608 ISLAND.SCN07/05/1995 13:28 359'800 LWOOD.SCN07/05/1995 13:22 361'712 LIGHTNIN.SCN07/05/1995 13:31 373'676 CUTROOFT.SCN07/05/1995 13:18 410'624 CUTALSHO.SCN07/05/1995 13:20 411'440 BARN.SCN07/05/1995 13:21 427'360 CLOSEUP.SCN07/05/1995 13:19 430'888 PASTBAR.SCN07/05/1995 13:31 432'840 ROOFTOPS.SCN07/05/1995 13:22 435'376 DRAGCAGE.SCN07/05/1995 13:36 443'664 CUTTOILE.SCN07/05/1995 13:34 445'696 STREET.SCN07/05/1995 13:32 454'344 DEATHSHA.SCN07/05/1995 13:25 461'196 PASTINNR.SCN07/05/1995 13:27 466'304 PASTLIBR.SCN07/05/1995 13:30 475'920 PASTPUB.SCN07/05/1995 13:23 486'192 DEATHDUN.SCN07/05/1995 13:15 489'240 PERFECT1.SCN07/05/1995 13:36 496'592 CUTTHRON.SCN07/05/1995 13:37 511'960 UNIGARD.SCN07/05/1995 13:29 538'024 MINE.SCN25/02/2001 18:12 540'325 DWB.EXE07/05/1995 13:14 552'844 CUSTARD.SCN07/05/1995 13:19 569'984 BAR.SCN07/05/1995 13:23 595'016 DUNNYMAN.SCN07/05/1995 13:25 599'176 INN.SCN07/05/1995 13:18 599'356 ALSHOP.SCN07/05/1995 13:32 601'928 PASTSHAD.SCN07/05/1995 13:36 607'440 THRONE.SCN07/05/1995 13:16 616'508 ALLEY.SCN07/05/1995 13:23 623'592 DUNGEON.SCN07/05/1995 13:37 623'904 UNSEEN.SCN07/05/1995 13:24 633'884 HAT.SCN07/05/1995 13:31 639'340 RINCEROO.SCN07/05/1995 13:26 653'372 INTROSHA.SCN07/05/1995 13:24 654'120 GODS.SCN07/05/1995 13:16 673'248 TURTLE2.SCN07/05/1995 13:32 700'840 SPIRE.SCN07/05/1995 13:24 719'080 GORGE.SCN07/05/1995 13:20 736'540 CUTBARN.SCN07/05/1995 13:31 751'964 SHADES.SCN07/05/1995 13:27 757'416 LIBRARY.SCN07/05/1995 13:28 773'728 LSPACE.SCN07/05/1995 13:37 776'188 DW.SCN07/05/1995 13:13 782'344 FINALE.SCN07/05/1995 13:16 829'536 TURTLE.SCN07/05/1995 13:34 863'292 SQUARE3.SCN07/05/1995 13:33 872'900 SQUARE.SCN07/05/1995 13:38 882'402 MIDI.DAT07/05/1995 13:22 915'504 DINING.SCN07/05/1995 13:33 929'452 SQUARE2.SCN07/05/1995 13:28 974'324 MAGBOOK.SCN07/05/1995 13:15 979'052 CLIMAX.SCN190 File(s) 51'318'986 bytes3 Dir(s) 3'634'130'944 bytes free[/size]
V.
It would be much easier for the guy, Vlad, if you just made an SFV and attached it. That's a lot of files to manually check sizes of.
Yes, it’s my fault.
Well, he can always get GNU "util" Win32 port. All you need is awk and diff. Otherwise can always use Excel.
What's SFV anyway?
V.
SFV = Simple File Verification. It's basically a file with CRC32 checksums.
eg. For the DOS4GW files:
; Generated by WIN-SFV32 v1 [added for sfv32 compatibility]; Using hkSFV32 on 08.22.2002 at 08:53:00; [url]http://www.big-o-software.com/software/[/url];1_6.EXE 099EFB691_8.EXE 323764221_9.EXE 7DD43C8B1_92.EXE C8E3CF7D1_95.EXE 95D35B4D1_95_2.EXE 3B750E061_97.EXE 5CC34B0F1_97_2.EXE CB2144471_97_3.EXE EA7106EB2_01A.EXE A47C6A1F
Note: Big-O Software's hkSFV32 is probably the best SFV program I've found. However, the Big-O site is dead, at least at the moment. There are, however, tonnes of other SFV utilities. I'm not actually sure WHERE I found my copy of hkSFV32, heh... I suppose you can always check the FastTrack or Gnutella networks for it. (It is freeware.)
Yes, it’s my fault.
I can play the Discworld version from Underdogs under XP with SB sound and midi music without VDMS. The drawback is that you must use the basic 8bit SB2.0 driver.
Yeah, that's WinXP's crappy built-in DOS sound support.
Vlad, seriously, give the guy an SFV file so he can check his files. Um, also, just since you haven't, please read the POSTING GUIDELINES. Thaaaanks.
Yes, it’s my fault.
wrote:I can play the Discworld version from Underdogs under XP with SB sound and midi music without VDMS. The drawback is that you must use the basic 8bit SB2.0 driver.
Good, so the game works without VDMSound. But what on earth happens when you run it *with* VDMSound? No sound? Then what most certainly happened is that you ran CONFIG.BAT *without* VDMSound (bad!), ao the game auto-detected WinXP's settings (i.e. IRQ5), and not VDMSound's settings (IRQ7). So it would then be normal to get sound *without* VDMSound and no sound with VDMSound. If you mean to run the game with VDMSound then please run the CONFIG program with VDMSound as well!
V.
wrote:I finished Discworld2 using VDMSound under WXP. It had some issues with speech like Full Throttle, but it didn't bother me.
Not sure if you will ever see this, but can you tell me how you got Discworld 2 to run under XP please? I've tried everything I can think of and it's just not happening.
I tried to install the DOS version earlier in an XP DOS window but kept getting a "No supported SuperVGA chip detected!" error, so that was the end of that experiment.
Use VDMSound and check "Enable VESA" or whatever in the VDMS Launchpad.
Yes, it’s my fault.
Thanks, I'll give that a try.
It was a no-go unfortunately. The DOS install program starts for DW2 and no longer gives the SuperVGA error, but now it just kicks back to the desktop for seemingly no reason shortly after.
Trying to reuse the shortcut that LaunchPad created just crashes Windows Explorer.
Thanks anyway though.
That's really weird, since I can get it to run fine here. What are your system specs? (POSTING GUIDELINES!!)
Yes, it’s my fault.
wrote:Trying to reuse the shortcut that LaunchPad created just crashes Windows Explorer.
What do you mean by "Trying to reuse the shortcut"? Double-clicking on it again, or popping up the properties? Also, could you please give as mcuh detail as possible (e.g. screenshot of error message/box) about the Explorer crash?
V.
I mean double-clicking it, it causes Windows Explorer to crash immediately. Unfortunately there is no pertinent information in the crash (other than it is in module kernel32.dll) but I will try and grab a screenshot of it shortly.
Specs:
Soyo K7V Dragon Plus Motherboard (VIA KT266A)
AMD Athlon XP 1700+ (1.47GHz)
512MB Crucial PC-2100 DDR
Gainward GeForce3 Ti 200 64MB (Detonator 31.00)
C-Media CMI8738 On-board Audio (latest drivers, v639)
Windows XP Pro, SP1
I know it's a bit of an imposition, but you possibly give me a run-through of exactly what you do after putting the DW2 CD in the drive please? I might be doing something wrong (though I'm not sure what).
Should also say I'm using the latest version of VDMSound (with Update 1) and LaunchPad.
Here is a step-by-step to show what I did.
Put the Discworld 2 CD1 in the drive (Lite-On DVD-ROM, LTD-163) (should also point out that this is the European version, Discworld 2: Missing Presumed...!? as opposed to the US release called Discworld 2: Mortality Bytes, although they are the same games, just different titles) and cancelled the autorun screen that pops up to prompt me to install the Windows version (as this doesn't work under XP).
Navigated to the drive with Windows Explorer, right click "install.bat" and pick "Run With VDMS" with the little icon" -> Custom Configuration -> Create New -> Advanced -> Compatibility -> Check "Enable basic VESA support" -> Next -> Uncheck "Remember" (as it's on a CD-ROM so it gives an error about not being able to write to the disk otherwise, which is obvious as it's a DVD drive and can't write to CDs) -> Finish.
The screen goes black, I see some messages flash by about DOS4GW runtime or something like that, then it kicks back to the desktop.
I then tried copying the whole CD to the hard drive and trying it that way, which is when the shortcut does get created in the folder (as I check the "Remember" part). I get kicked back to the desktop again, then when I double-click the shortcut to run it again, Windows Explorer crashes with an error in kernel32.dll as shown.
Hmm, it does not seem to be crashing Explorer now, not sure why as it did before. Each time I try to reuse the shortcut VDMS made (double-clicking) it just does as before, gives the black screen, goes through something about DOS4GW then back to the desktop, so I'm clueless as to what is going on 🙁
Try to get the US version from theunderdogs.org and see if behaves the same. I'm asking because I finished DW2 (from the UDogs) uinder Win2k with VDMSound and it worked "out of the box" without problems (no fancy settings or tricks, just "Run with VDMS" in LaunchPad).
When you get the Explorer crash, do you get something like "Press OK to exit, press Cancel to debug"? I want you, if you ever get this again, to trigger a stack trace (by pressing Cancel I presume) at which point wither Dr. Watson will pop up (don't cancel Dr. Watson though!) and will write some information in C:\Documents and Settings\All Users\Documents\DrWatson\drwtsn32.log, or the Microsoft debugger will pop up if you have Visual Studio installed (at which point you can see the stack trace from one of the menus, I think the "Debug" or "View" or whatever it is called menu).
Thanks,
V.
