I.M. Meen Never Loads?
First post, by supersam966
Ok. I just got I.M. Installed, I Mounted the Game Drive and everything, I ran the INSTALL Executable. And then I exit to DOS, The Prompt says "TYPE IMMEEN TO PLAY", I did as it asked. DOSBox just stays a black screen with nothing on it, And the mouse is trapped unless I Alt+Tab.
Is there anything I'm doing wrong, or Anyway to fix this?
By the Way I'm using Vista Home Premium and The Lastest Version of DOSBox.
