First post, by insectoid
- Newbie
I have recently begun recording game music using DOSBox, and it records just fine. (I changed the sample rate in dosbox.conf to 44100 for this purpose.)
However, there's just one thing that bothers me: changing the capture folder on-the-fly (using the config command) has no effect whatsoever when I record--it puts the recordings in C:\Program Files\DOSBox-0.73\capture anyway. (Changing the sample rate with config had no effect either, but I meant to change it in the conf anyway.)
The folders I specify do exist; I tried both making folders in DOSBox-0.73, and also subfolders in DOSBox-0.73\capture, and used the config command:
config -set "dosbox captures=newfolder"
But neither way made any difference; they just wound up in capture. I've never had trouble changing other settings during runtime (like CPU cycles). Can someone explain this?
-Insectoid
Intel Pentium D 935/3.2, 1GB RAM, Windows XP Home, DOSBox 0.73.
