SDL patch (fixes memory leak in DirectDraw backend)
First post, by Kippesoep
As discussed in the #dosbox IRC channel.
This fixes the memory leak h-a-l-9000 experienced on SDL_SetVideoMode.
    bugfix.diff
    1.16 KiB
    65 downloads
    Patch for SDL 1.2.13.
Reply 1 of 7, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
could you elaborate just a bit? And does this patch SDL or Dosbox? And anyway, can a mod move it to the patches forum, so I can find it again, when the need arises? 😀
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 3 of 7, by Kippesoep
Since the SDL people aren't likely to respond any time soon, attached is an updated DLL file that incorporates the fix (as well as the regular DOSBox-specific changes).
    SDL.zip
    112.32 KiB
    33 downloads
    Patched DLL
Reply 4 of 7, by Good Ol' TarviS
I'm sorry about bumping this, but why is this not included in more recent builds (namely those with direct3d output support?) Changing modes is nearly instant with this SDL.DLL compared with the stock one in ykhwong's build. At least I've noticed this is System Shock, which goes back to 320x200 whenever the main menu or map is brought up.
Reply 7 of 7, by Kippesoep
This has nothing to do with the speed of mode switching. All it does is fix one memory leak when using DirectDraw. It does absolutely nothing with OpenGL. Any improvements in speed are purely coincidental except in edge cases and are much more likely due to your graphics card driver. This is not a performance patch. It is a memory bugfix.
My site: Ramblings on mostly tech stuff.
