First post, by aqrit
Use IA-32 hardware breakpoints and win32 structured exception handling to signal the dosbox debugger to break execution of an emulated DOS game.
Break read/write/code(read) (limit 4 breakpoints)
Breakpoints with little performance loss
Convert memory addresses between dosbox environment and windows environment
( by adding or subtracting MemBase )
Code was not tested too much...
Source code and DIFF files should be attached to this post.
How it works:
Set host debug registers from the dosbox.debugger cmdline.
wrap dosbox.host_read/write() in try/catch blocks.
References
"Toggle hardware breakpoints" article by Michael Chourdakis
http://www.codeproject.com/KB/debug/hardwarebreakpoint.aspx
Intel® 64 and IA-32 Architectures Software Developer's Manuals
http://www.intel.com/products/processor/manuals/
