First post, by jbrave
jbrave
Offline
There is an editor for the Kawai K3 synthesizer (and a few others, have one for the Kawai K5 as well) that runs in DosBox. I have it running. Only problem is, getting MIDI out. Any help with getting midi transmitted out either directly to the hardware midi on my Mac, or to the Inter-Application midi where I could feed it into Logic and then out to a hardware port, would be helpful. I have it configured as MPU-401 which should work with most ancient DOS MIDI applications.
Thanks!
Joel
