First post, by fmillion
Pardon me if this is a silly question but I couldn't really find any good help with searching..
Is there a way to install apps in DOSBox that come on multiple floppies, if you don't have a floppy drive but have disk images of the floppies?
You know, when an app goes "remove disk 1 and insert the next disk" and just copying all the files to one directory won't work (like when it uses volume labels to check which disk is in)
the BOOT command will let you swap floppies after BOOTING a game off a floppy, but how about just installing a game into the DOSBox environment's C drive?
This seems to be something simple that there should be an easy solution for but I'm not finding it... Help anyone?
thanks
FM
