First post, by Guyper
Hi,
I have the cd-rom version. When the installation asked me which drive do I want to copy the files from, I kept pressing D (I know I mounted it correctly) but nothing happened. I tried with previous versions as well.
Thank you.
Reply 1 of 9, by Xelasarg
I think I had the same issue installing WC2 from CD. Problem is, I don't recall how I solved it, I've simply been copying it from one PC to another since.
I've attached a zip file containing my install.dat and wc2.cfg files. Maybe it'll help to unzip them into your WC folder.
    Wc2_cfg.zip
    1.97 KiB
    317 downloads
"What's a paladin?!"
Reply 3 of 9, by Xelasarg
Set SB IRQ to 7 in your dosbox.conf (I' made a new one for WC2 actually). Maybe you'll have to add the following line to the autoexec section: set blaster=a220 i7 d1 t6
Reply 4 of 9, by MiniMax
Rank Moderator
Moderator
NO!
DOSBox will automagically create the correct BLASTER variable based on the other settings in the configuration file.
_________________
Reply 7 of 9, by ripa
The game worked for me "out of the box" (sound and all):
mount c c:\games\old
mount d d:\ -t cdrom
d:
winstall.bat
"Select save game drive:" - picked C
"Sound System Installation" - picked Creative Sound Blaster
"Speech selection" - picked Yes
"Sound Blaster Pro DMA Select" - picked DMA 1
"Correct config?" - picked Yes
"Installation complete." typed wc2 at d:\> and voila.
PS. I recommend creating a CD image. Having the game load data from the CD makes the game stutter.
